> Weber 44 running rich
Dave97
post Oct 7 2017, 05:19 PM
2270 with Weber 44 is running rich
50 idle. 1 1/4 screw out
Had 55. Drives better, but the a/f stayed about the same
135 main
175 air
Floats set at 9 with gasket
Have wideband sensor
11.0 at idle
Light throttle might see 12.8
Decel 13.2
Full throttle 13.7
Is there a air by pass circuit? It's almost the opposite of a air leak
Thanks for your help
Elliot Cannon
post Oct 7 2017, 06:51 PM
Group: Retired Members
My engine is just a bit smaller than yours. 76 crank and 96 P&C. 44idf.
I use 130 main
175 air
55 idle
32 venturis
I believe my floats are set a 10 without the gasket. I would try a smaller venturi. It's easy to change. My car still doesn't come off idle as smooth as I would like but I'm just too lazy to experiment around with the idle jets.
Dave97   Weber 44 running rich   Oct 7 2017, 05:19 PM
porschetub   2270 with Weber 44 is running rich 50 idle. 1 1/4...   Oct 7 2017, 06:15 PM
Perry Kiehl   You don't say what size venturi. It's not...   Oct 7 2017, 06:27 PM
Dave97   Bought the car with them. I think 36. Wouldn...   Oct 7 2017, 06:37 PM
Elliot Cannon   My engine is just a bit smaller than yours. 76 cr...   Oct 7 2017, 06:51 PM
Gatornapper   I read about 36 venturi's and 32 venturi's...   Oct 13 2017, 05:21 PM
Dave97   And cylinder head temp light throttle is 200 with ...   Oct 7 2017, 07:38 PM
Elliot Cannon   Mine runs at 325 at 75 mph. 350 or more up hill, ...   Oct 7 2017, 07:55 PM
Dave97   Mine runs at 325 at 75 mph. 350 or more up hill,...   Oct 7 2017, 09:51 PM
Elliot Cannon   Mine runs at 325 at 75 mph. 350 or more up hill...   Oct 8 2017, 12:43 AM
Gatornapper   I have no business replying as I am rebuilding my ...   Oct 7 2017, 11:08 PM
McMark   Do you know what cam is in there? Lots of over la...   Oct 8 2017, 06:54 AM
McMark   I think you have a lot of different issues going...   Oct 9 2017, 06:32 AM
Dave97   Thanks. I got 13.1 a/f but with the idle mix screw...   Oct 9 2017, 04:54 PM
Elliot Cannon   Venturis and jets are relatively inexpensive items...   Oct 13 2017, 07:16 PM
Gatornapper   Know that well from years of fiddling with carbs. ...   Oct 13 2017, 07:49 PM
porschetub   Sir Andy and Elliot supplied the magic answer ,the...   Oct 13 2017, 08:30 PM
Gatornapper   PRECISELY what I was looking for. Have the 32 ven...   Oct 13 2017, 09:00 PM
rhodyguy   Just perform the pre-install procedure detailed in...   Oct 14 2017, 10:41 AM
Perry Kiehl   PM's sent   Oct 14 2017, 12:24 PM
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 24th November 2024 - 01:43 AM
