> Why is my brake/hazard light still flashing?, Tested everything I can think of so far
Matty900
post Oct 7 2017, 08:52 AM
My multi gauge in my 72 will not stop flashing (IMG:style_emoticons/default/chair.gif)
First thought was that I needed to reset the master cylinder after the breaks were done. I did that - Still flashing
I checked the switch on the emergency brake. I had connected one of the wires for the back pad light to it (IMG:style_emoticons/default/headbang.gif) Fixed that
- Still flashing
I was blowing a fuse for the drivers side signals. After reading posts I thought this could be indicating I had an issue with lights. I tracked down the ground, fixed the problem - Still flashing
I had replaced almost all of the lights in the dash with LEDs. So after reading posts about how the flasher relay works, I swapped these 2 lights and the turn signal lights in the tac back to regular bulbs - Still flashing
Any ideas?
arne
post Oct 7 2017, 07:25 PM
Serial Rescuer of old vehicles...
My car’s 2 wire master cylinder switch was faulty, I could not make it stop flashing until I converted it to a 1 wire switch.
- Lo-Fi Version Time is now: 27th December 2024 - 11:23 PM
