Engine Cases, Mating Surfaces |
Allan |
Nov 4 2004, 11:31 AM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
What is the best way to clean all of old permatex from the the sealing surfaces of the engine cases before re-assembly without taking away any of the metal. I don't want to create uneven areas that could lead to leaks.
Carrera916 |
Nov 4 2004, 11:52 AM
Member Group: Members Posts: 292 Joined: 9-February 03 From: Pleasanton, CA Member No.: 273 |
I usually spray a bit of carb cleaner on the edge of case to let the old glue soften up a bit.....I have a tri-blade scrapper that I always use to scrap the old glue out without shaving any metals off....maybe a couple on subborn areas (IMG:style_emoticons/default/wink.gif)
Then do it again with the carb cleaner and clean white rag to go over the edge, it should come right out... j |
Lo-Fi Version | Time is now: 27th September 2024 - 07:14 PM |
