Bad day at cars & coffee, Big noise on the way home |
80cap |
Oct 7 2017, 12:59 PM
Member Group: Members Posts: 320 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
While leaving cars & coffee I heard a little back fire and a valve train noise on the driver side. Towed home and searched the cyber web and I determined that I experienced a dropped valve seat. I'll drop the engine tomorrow and pull both heads because I used a not so hot engine guy last time. I need to search out a good heads to purchase. I don't want to repeat the same mistake. Please feel free to make fun of me or suggest a good source for new heads. (IMG:style_emoticons/default/headbang.gif)
TheCabinetmaker |
Oct 8 2017, 02:56 PM
I drive my car everyday Group: Members Posts: 8,325 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Might not want to blame the head builder yet (even though it could be his fault). Type 4 seats are notorious for falling out. Especially old heads. They repeatedly get too hot then cool off. The seats come loose from the heat and finally just fall out. Remember, your heads are probably 40 years old and have had thousands of heat cycles.
DM_2000 |
Oct 8 2017, 03:09 PM
Member Group: Members Posts: 217 Joined: 16-August 17 From: PA Member No.: 21,351 Region Association: None |
Might not want to blame the head builder yet (even though it could be his fault). Type 4 seats are notorious for falling out. Especially old heads. They repeatedly get too hot then cool off. The seats come loose from the heat and finally just fall out. Remember, your heads are probably 40 years old and have had thousands of heat cycles. The question is, What should the head rebuilder have done to prevent a seat from coming out? ( Yes, I'm aware that you seem to be taking a middle ground here. ) If the rebuilder recommended new out of the box heads, I'm betting there would be those on this list saying he just wanted to make more $. It's no wonder that some shops say no to older / odd engines. |
Lo-Fi Version | Time is now: 28th December 2024 - 12:01 AM |
