Weber 44 IDF's - keep - or find original d-jet? |
Gatornapper |
Oct 9 2017, 04:03 PM
Senior Member Group: Members Posts: 1,241 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Questions re: Weber 44 IDF carbs:
1. Is anyone running these on a stock engine, and if so, how do they perform? National Carburetors kit for stock engines is 34 ICT's, lightly modified 40 IDF's, and only 44's on heavily modified engines. 2. What problems do you introduce using 44's? other than dumping too much fuel in the engine...... 3. Venturi's are 45mm, someone pointed out that one should use 40mm venturi's - is that with a stock engine? 4. Anyone run 44's and then convert back to EFI? How did that go? Labor cost? TIA, GN |
BillC |
Oct 9 2017, 04:36 PM
Senior Member Group: Members Posts: 550 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
It'll be more work than just slapping on a set of carbs, but I think you'll be happier in the long run if you install the original D-Jet setup. Plus, the car will be worth more once it's all done.
If you're going to stick with carbs, the 44s are too big for a stock engine. The 40s might work for a 2.0, but might be too big if you still have the stock cam. The 34s will give you the best drivability around town and fuel mileage, but you might sacrifice a little on the top end on a 2.0. |
Gatornapper |
Oct 9 2017, 05:31 PM
Bill -
I restore old motorcycles so I know the more original, the more the value.... The 44's are on the car now & I'm rebuilding them. My good friend in whose barn the car has sit for 10 years said the car was running perfectly when it was driven in the barn and he had been riding in it with the PO (another friend of his) that day. I'm now thinking I want to flip the car ASAP. Will the car run ok with the 44's? 10mpg? And where would I start looking for the original D-Jet setup and how do I know I'm getting a full, properly working system? Reliable sources? Thanks! GN It'll be more work than just slapping on a set of carbs, but I think you'll be happier in the long run if you install the original D-Jet setup. Plus, the car will be worth more once it's all done. If you're going to stick with carbs, the 44s are too big for a stock engine. The 40s might work for a 2.0, but might be too big if you still have the stock cam. The 34s will give you the best drivability around town and fuel mileage, but you might sacrifice a little on the top end on a 2.0. |
Lo-Fi Version | Time is now: 26th June 2024 - 02:57 AM |
