Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,679 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
As mentioned we've been working on these for some time. Just getting to finishing these up.
They change the airflow to help cool the engine better. $28 A set who's in? |
nditiz1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,191 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region ![]() ![]() |
Do these work better than the stock ones?
Mikey914 |
Do these work better than the stock ones? The stock one work ok, we have been playing with adding some small "wingtip" vortex generators. On the edges, it's a part that could be cut off for the concourse crowd, but would help improve the movement of air. I generally like to spring options right before the parts are ready, but yes there will be an improvement for those that want it. (IMG:style_emoticons/default/biggrin.gif) |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Do these work better than the stock ones? The stock one work ok, we have been playing with adding some small "wingtip" vortex generators. On the edges, it's a part that could be cut off for the concourse crowd, but would help improve the movement of air. I generally like to spring options right before the parts are ready, but yes there will be an improvement for those that want it. (IMG:style_emoticons/default/biggrin.gif) How many volts? (IMG:style_emoticons/default/smile.gif) Put me down for a set of "improved" upon design if make one. |
Lo-Fi Version | Time is now: 20th June 2024 - 09:12 AM |
