> L-Jet Auxillary Air Regulator or Valve?, Proper operation of the AAR
malcolm2
post Oct 17 2017, 12:38 PM
I found an very old, very short post about the subject and cleaning the AAR with PB Blaster. So I guess I'll try that. But that post did not answer my current problem.
I have had my AAR off of my car and the hose connections plugged for about 6 months now. But it is getting cold and it has been recommended that I put it back in service. So I tested it. And took some pictures along the way. I did the FREEZER test and it opened.
I sat it in the sun. Very warm exterior case. Kinda tuff to hold it. It absorbed a good bit of heat.... and almost closed.
Then I broke out my handy dandy 12v drill battery and within a few seconds it was closed.
here is the question..... I tried to blow thru the closed hole and had ZERO problem doing that. So I suppose when closed that NO AIR should pass thru, correct? Will the PB Blaster cleaning help, or is this baby done for? Any ideas on fixing?
Thanks.
malcolm2   L-Jet Auxillary Air Regulator or Valve?   Oct 17 2017, 12:38 PM
timothy_nd28   If you can blow thru the AAR after it fully closed...   Oct 17 2017, 01:37 PM
malcolm2   I remember that you suggested a BRAND new one.....   Oct 17 2017, 03:30 PM
jim_hoyland   The force of blowing air through the AAR far excee...   Oct 17 2017, 04:31 PM
pete000   The force of blowing air through the AAR far exce...   Oct 17 2017, 06:58 PM
echocanyons   I think new ones are only a available for a small ...   Oct 17 2017, 06:58 PM
pete000   I think new ones are only a available for a small...   Oct 17 2017, 07:04 PM
Dave_Darling   I believe that early 944 ones can be adapted to wo...   Oct 17 2017, 08:18 PM
porschetub   I believe that early 944 ones can be adapted to w...   Oct 18 2017, 04:29 PM
ClayPerrine   Aux Air Regulator for sale at Bus Depot $1...   Oct 18 2017, 04:35 PM
malcolm2   Aux Air Regulator for sale at Bus Depot ...   Oct 18 2017, 07:19 PM
Philip W.   I have one of those that I bought a long time ago ...   Oct 19 2017, 08:10 AM
malcolm2   I have one of those that I bought a long time ago...   Oct 19 2017, 10:47 AM
Philip W.   I have one of those that I bought a long time ag...   Oct 26 2017, 10:52 AM
ClayPerrine   It is not designed to be closed completely. There ...   Oct 26 2017, 12:36 PM
malcolm2   It is not designed to be closed completely. There...   Oct 30 2017, 07:54 AM
ndfrigi   Like Jim and Clay said, same when i still have my ...   Oct 26 2017, 01:58 PM
Philip W.   :beer2: awesome! let us know how it car runs ...   Oct 30 2017, 08:03 AM
malcolm2   :beer2: awesome! let us know how it car runs...   Nov 13 2017, 09:57 AM
timothy_nd28   Since your AAV is now functioning correctly, I wou...   Nov 13 2017, 04:45 PM
- Lo-Fi Version Time is now: 27th December 2024 - 09:54 AM
