L-Jet Auxillary Air Regulator or Valve?, Proper operation of the AAR |
malcolm2 |
Oct 17 2017, 12:38 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I found an very old, very short post about the subject and cleaning the AAR with PB Blaster. So I guess I'll try that. But that post did not answer my current problem.
I have had my AAR off of my car and the hose connections plugged for about 6 months now. But it is getting cold and it has been recommended that I put it back in service. So I tested it. And took some pictures along the way. I did the FREEZER test and it opened. I sat it in the sun. Very warm exterior case. Kinda tuff to hold it. It absorbed a good bit of heat.... and almost closed. Then I broke out my handy dandy 12v drill battery and within a few seconds it was closed. here is the question..... I tried to blow thru the closed hole and had ZERO problem doing that. So I suppose when closed that NO AIR should pass thru, correct? Will the PB Blaster cleaning help, or is this baby done for? Any ideas on fixing? Thanks. |
echocanyons |
Oct 17 2017, 06:58 PM
Advanced Member Group: Benefactors Posts: 2,096 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
I think new ones are only a available for a small fortune or for a few select organs.
Does anyone know where to find a new one for a reasonable price? Does anyone rebuild these things? |
pete000 |
Oct 17 2017, 07:04 PM
Senior Member Group: Members Posts: 1,886 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
I think new ones are only a available for a small fortune or for a few select organs. Does anyone know where to find a new one for a reasonable price? Does anyone rebuild these things? Check around, they can be found and even really old ones can usually be freed up soaking them in kerosene or oil solvents. Run a WTB ad... |
Lo-Fi Version | Time is now: 27th December 2024 - 10:35 AM |
