Refinishing: Magnesium Fan Shroud & Transmission Case, Need Advice |
914_7T3 |
Oct 19 2017, 01:21 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,862 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
In reading up on some older threads, it has been stated that the Fan Shroud & Transmission Cases are Magnesium.
I have the shroud out for media blasting along with the engine tin etc.... Once completed should the shroud be finished with a high heat clear paint such as a Krylon that is rated up to 600 degrees. Also should there be any type of prep done between these steps. I want it to look right, but do not know if they were coated from the factory or should be left in the original finish. On that note the transmission case will not be blasted, but it was suggested that it be cleaned up with a wire brush and steel wool. Is that the correct way to go and similar to the shroud does it require a clear painted finish or just leave it alone. Here is a pic of a small section that I went over with steel wool after degreasing. Lastly, once the Muffler is blasted, does that require a high heat ceramic coating? If I do not coat it, will that just accelerate any future surface corrosion? Don't really want to spend 1/2 the value of a new muffler heat coating the old one. Any advice? |
cal44 |
Oct 19 2017, 02:56 PM
Member Group: Members Posts: 165 Joined: 8-October 09 From: Encinitas, Ca. Member No.: 10,910 Region Association: Southwest Region |
As the others mentioned.......wire brush?.....NO
Like Dr. Evil I'm also from San Diego.......wait......I still live here. Bronze wool, I use fine grade. It's a secret weapon few car guys know about. The boating pros use the bronze as it doesn't rust when tiny particles are not cleaned up and puts a smooooth finish to the surface. It does wonders on old chrome, doesn't dig in to aluminum either. Been using it for decades. If you can't find it locally, order on line and make sure to shop the price, wide variations. As for coatings, PRO clear can spray, Rustoluem clear. We just did a '66 Bronco Roadster that had all original factory chalk marks thru out. We did five layers of Rustoleum clear. It had a very low gloss and the marks are now safe and quite visible. Por-15 is supposed to have a crystal clear coating but I have yet to give it a go. Do not use Por-15 clear rust sealer. We use Kano Labs degreaser as our first step. |
Lo-Fi Version | Time is now: 28th September 2024 - 09:05 AM |
