914_7T3 |
Please forgive me, I'm new to all of this! ![]() ![]() ![]() Group: Members Posts: 1,854 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California ![]() ![]() |
In reading up on some older threads, it has been stated that the Fan Shroud & Transmission Cases are Magnesium.
I have the shroud out for media blasting along with the engine tin etc.... Once completed should the shroud be finished with a high heat clear paint such as a Krylon that is rated up to 600 degrees. Also should there be any type of prep done between these steps. I want it to look right, but do not know if they were coated from the factory or should be left in the original finish. On that note the transmission case will not be blasted, but it was suggested that it be cleaned up with a wire brush and steel wool. Is that the correct way to go and similar to the shroud does it require a clear painted finish or just leave it alone. Here is a pic of a small section that I went over with steel wool after degreasing. ![]() ![]() Lastly, once the Muffler is blasted, does that require a high heat ceramic coating? If I do not coat it, will that just accelerate any future surface corrosion? Don't really want to spend 1/2 the value of a new muffler heat coating the old one. Any advice? |
DM_2000 |
Member ![]() ![]() Group: Members Posts: 217 Joined: 16-August 17 From: PA Member No.: 21,351 Region Association: None ![]() |
Paint would be fine. On steel wheels I've used machine gray then before it drys, dusted stainless over top to give a slight bit of sparkle ( both were Rustoleum in a spray can. ) The gray was too bland , stainless too bright. Argent is a common wheel color but that was a bit too bright.
Lo-Fi Version | Time is now: 27th June 2024 - 06:40 PM |
