> Easy as 1 2 3, Got it yesterday, pushed all projects aside!
mgphoto
post Sep 28 2017, 03:54 PM
"If there is a mistake it will find me"
Got the 123Ignition yesterday, I pushed all of my projects back!
"Sorry granny I'll get to those bearings on your heart/lung machine soon, I promise."
Blocked out 3 hours for the removal and install.
Added about an hour to charge the battery.
Installed as expected, there is a spacer that is necessary for type 4, just slides over the dizzy shaft.
I decided to route the wires and vacuum away from the fan so access to the vacuum nipple was easier, since the vacuum can is gone there's a lot more space.
Followed the instructions but made the mistake of using the TDC 0* instead of the 27* as the basic timing point. I just walked the dizzy CCW until she started!
Didn't do anything other than matched my timing with my idle, I let her run till she settled down.
Just around the block once, ha ha the trailer hitching is GONE!
Responsive throttle, man!
Setting up a tuning session, nice 150 mile run up the California coast with the AFR meter.
Mike
mgphoto
post Oct 24 2017, 11:36 AM
So the miss I find is a loose injector connector, yeah remember D-Jet connectors.
I've been taking the car on 20 to 30 mile test runs, dealing with ambiant temps and fuel octane.
There has been a real Jeckell and Hyde situation, one run good and strong, another lots of ping and no power at WOT.
I started to lean to the temp issue. Until yesterday, we had 99 to 102* F I took the car for an 80 mile run through a few stressing circumstances.
After 6 miles, engine not even up to running temps she felt like, I've heard the English use the term "lumpy."
I was heading into a downhill section of the 14 FWY north, I pushed the throttle to max, she responded.
From that point on she was Jeckell! The temps outside were brutal, but as long as I was hitting 85 most of the time the breeze was nice.
Since the loose injector wire I've done nothing under the hood except adjust the idle using the air bypass screw, which has been varying from 600 to 1300 RPM. So after reading another 123 post, I will start expermenting with removing the retard vacuum line. I had a problem with low idle with the headlights on, doesn't help the lightend flywheel any.
Here is where I start to examine the fuel issue. After an internet search for Summer/Winter fuel blend info. Did you know that they add butane to gasoline in the summer months.
My normal fuel is not the best gas ever, so I suspect this might be the issue.
I found some 100 octane "race fuel" at a Sonoco station in Pasadena.
I have been mixing that with the 91 octane. By blending both fuels I been able to find a point that makes the car run without pinging.
Yesterdays blend was about 94 octane. Even with stressing the engine with full throttle uphill acceleration no pinging. I did hear a singular ping on occasion, seemed to happen between off throttle and WOT at 3500 to 4000 RPM.
Oil temps never went over 215* F.
Next I will burn off the 94 octane and use a high quality 91 octane.
When I get what I consider a stable ignition I will begin checking the FI with the AFR meter.
Stay tuned.
BeatNavy
post Oct 24 2017, 12:59 PM
Cool, thanks for the pictures. So now I know it's advance curve "b" when mine arrives (IMG:style_emoticons/default/smile.gif)
QUOTE(mgphoto @ Oct 24 2017, 01:36 PM) *
I've had that happen to me a couple of times in the last few weeks (IMG:style_emoticons/default/dry.gif) . Need to figure out what the "trick" is (e.g., getting those little "boots" over the injectors...?)
mgphoto
post Oct 24 2017, 01:58 PM
QUOTE(BeatNavy @ Oct 24 2017, 11:59 AM) *
Hey BeatNavy,
I might change the curve after I do some more research and remove the retard vacuum line.
Use the boots, if you got them. The original style has pull tabs on either side of the boot. Newer Bowsby style doesn't have the tabs, but the rubber is newer and much more supple.
mgphoto   Easy as 1 2 3   Sep 28 2017, 03:54 PM
76-914   Got the 123Ignition yesterday, I pushed all of my...   Sep 28 2017, 04:26 PM
Porschef   What was the distributor that you replaced with th...   Sep 28 2017, 05:10 PM
mgphoto   What was the distributor that you replaced with t...   Sep 28 2017, 05:32 PM
Montreal914   Nice! What's your engine, induction system...   Sep 29 2017, 08:26 AM
mgphoto   Nice! What's your engine, induction syste...   Sep 29 2017, 11:33 AM
Mblizzard   Really liked my 1 2 3. Did you get the programmab...   Sep 29 2017, 10:50 AM
mgphoto   Really liked my 1 2 3. Did you get the programma...   Sep 30 2017, 01:40 PM
914_teener   Really liked my 1 2 3. Did you get the programm...   Sep 30 2017, 02:13 PM
StratPlayer   Been running my 123 dist. for about a year now, mo...   Sep 29 2017, 07:24 PM
pete000   This has been on my want list for a while now. W...   Sep 29 2017, 08:49 PM
mgphoto   This has been on my want list for a while now. ...   Sep 30 2017, 01:37 PM
Porschef   :popcorn: :popcorn: :idea:   Sep 30 2017, 05:05 AM
StratPlayer   I bought mine from the manufacturer.   Sep 30 2017, 12:07 PM
mgphoto   Now for the ugly. I am Sorry, I am SORRY, I AM SO...   Sep 30 2017, 02:25 PM
pete000   Mine likes to run around 210 on the oil...   Sep 30 2017, 05:46 PM
Porschef   :popcorn: :popcorn: :rolleyes:   Oct 1 2017, 10:12 AM
mgphoto   OK so I am going through the ignition wiring, the ...   Oct 2 2017, 04:30 PM
cuddyk   Maybe a coil that's on its way out? Mine behav...   Oct 2 2017, 05:31 PM
123ignitionusa   Maybe a coil that's on its way out? Mine beha...   Nov 6 2017, 04:22 PM
Vacca Rabite   Ive got the 123 for my Bmw2002. I have yet to put...   Oct 3 2017, 10:31 AM
JoeD   Also been running a 123 on my 2270 dual-carbed Rab...   Oct 3 2017, 01:37 PM
mgphoto   So the miss I find is a loose injector connector, ...   Oct 24 2017, 11:36 AM
BeatNavy   Cool, thanks for the pictures. So now I know it...   Oct 24 2017, 12:59 PM
mgphoto   Cool, thanks for the pictures. So now I know it...   Oct 24 2017, 01:58 PM
Vacca Rabite   Sounds like you are well on the way. I hate electr...   Oct 24 2017, 12:10 PM
mgphoto   We all have a need to see.   Oct 24 2017, 12:26 PM
mgphoto   Don't know why they are 90* off in the post bu...   Oct 24 2017, 12:31 PM
mgphoto   FYI type 4 needs a spacer which should come with t...   Oct 24 2017, 12:34 PM
mgphoto   I took her out for an early spin on Saturday, 68*F...   Oct 30 2017, 12:15 PM
Mblizzard   I took her out for an early spin on Saturday, 68*...   Oct 30 2017, 01:42 PM
mgphoto   I took her out for an early spin on Saturday, 68...   Oct 30 2017, 02:07 PM
pete000   If the car did not ping with the stock distributor...   Oct 30 2017, 02:13 PM
914_teener   If the car did not ping with the stock distributo...   Oct 30 2017, 09:23 PM
mgphoto   If the car did not ping with the stock distributo...   Oct 31 2017, 10:45 AM
Rand   Early spark is the most common cause. Cylinder pr...   Oct 30 2017, 02:27 PM
Philip W.   i agree that your timing has to be off but also yo...   Oct 30 2017, 07:53 PM
mepstein   Our cars run on regular fuel. Unless modified, the...   Oct 30 2017, 08:20 PM
Rand   When you change a part that affects timing and you...   Oct 30 2017, 08:29 PM
mgphoto   I Rebuilt this dizzy when I built the motor about ...   Oct 31 2017, 10:49 AM
mgphoto   Ok this engine is not stock. J&E forged ...   Oct 31 2017, 11:16 AM
Mblizzard   Not sure this is helpful but attached is the curve...   Oct 31 2017, 12:57 PM
mgphoto   Ok nothing has changed, I did nothing to the car e...   Oct 31 2017, 03:07 PM
KELTY360   Ok nothing has changed, I did nothing to the car ...   Nov 6 2017, 05:51 PM
BeatNavy   I just ordered a new Bosch (Blue) coil, new plugs,...   Nov 6 2017, 05:51 PM
mgphoto   about 3 gallon of techron 91 left in the tank, too...   Nov 7 2017, 09:58 AM
mgphoto   Running on the last 2 gallons of the Chevron, I de...   Nov 13 2017, 03:37 PM
24 User(s) are reading this topic (24 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 10:22 PM
