> Suspension, What rear springs
qa1142
post Nov 4 2004, 08:56 PM
Whiplash
Ok, winter work is about to begin. I'll have stock front torsion bars, new boge shocks and 19mm Weltmeister front bar.
With stock rear boges, what rear spring will work best for street with occasional fun runs and/or autocross?
100# Weltsmeister? or something else?
Should I spring ( (IMG:style_emoticons/default/chairfall.gif) ) for adjustable rear purches?
Brad Roberts
post Nov 4 2004, 10:26 PM
914 Freak!
Here is what happens when you make a Koni change:
The effect: you are slightly increasing the front spring rate when you set them full hard and set the rear full soft.
Case in point: car is slinging the rear end around in tight slow speed corners... set front shocks more firm. This will keep the weight from transferring forward as quickly.
B
qa1142   Suspension   Nov 4 2004, 08:56 PM
Brad Roberts   140's are a good balance with the 19mm bar and...   Nov 4 2004, 09:30 PM
seanery   I like my 125s on adjustable perches, comfy, yet t...   Nov 4 2004, 09:49 PM
Brad Roberts   If he had ajustable shocks... I assumed he didnt w...   Nov 4 2004, 09:52 PM
ChrisReale   Im thinking about going back to stock front torsio...   Nov 4 2004, 09:52 PM
Brad Roberts   Stick with your current rear springs. The fronts n...   Nov 4 2004, 09:59 PM
Lawrence   I have adjustable Koni's all round (set full s...   Nov 4 2004, 10:01 PM
Brad Roberts   I just HATE the Weltmeister progressive springs. T...   Nov 4 2004, 10:05 PM
itsa914
  Nov 4 2004, 10:08 PM
Brad Roberts   Do you know what happens when you set the rears so...   Nov 4 2004, 10:10 PM
seanery   my guess would be that the car would rotate nicely...   Nov 4 2004, 10:13 PM
Brett W   Not really, it pushes. Yeah Will go with a linear...   Nov 4 2004, 10:17 PM
trekkor   I just want to say, I love the way my car is handl...   Nov 4 2004, 10:19 PM
Brad Roberts   See you at Sears Trekkor... It is great we can Au...   Nov 4 2004, 10:23 PM
trekkor   Fronts firm and rears soft works great for me. At ...   Nov 4 2004, 10:26 PM
Brad Roberts   Here is what happens when you make a Koni change: ...   Nov 4 2004, 10:26 PM
Brad Roberts   I went full soft on everyones cars at Candlestick....   Nov 4 2004, 10:27 PM
kermit   If you'll still be driving it on the street, 1...   Nov 4 2004, 11:26 PM
JOHNMAN   Where can I get a set of the threaded tubes & adju...   Dec 1 2004, 04:13 PM
Mueller     Dec 1 2004, 04:42 PM
JOHNMAN
  Dec 1 2004, 05:10 PM
Mueller   350 pounds?!?!?!? damn.....makes my t...   Dec 1 2004, 05:54 PM
- Lo-Fi Version Time is now: 21st December 2024 - 11:22 PM
