Challenge to anyone who knows-Still struggling with turn signals, cancel ring tab, turn signal operation |
domer914 |
Oct 25 2017, 11:55 AM
Newbie Group: Members Posts: 41 Joined: 19-December 09 From: Oklahoma Member No.: 11,149 Region Association: None |
So I have discovered that the black tab on the cancel ring has zero bearing on turn signal cancellation. How the hell is that?
I have been troubleshooting the fact that left turn signals cancel, and right turn signals will not. So I discovered that I have this problem regardless of how the ring is installed. The black tab can sit at 12, 3, 6 or 9 o'clock, and right turn signals will not cancel, while left will. arghhh |
SirAndy |
Oct 25 2017, 01:12 PM
Resident German Group: Admin Posts: 41,972 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Jack up the front of your car so both wheels are off the ground, only use the ring and hub without the steering wheel and see why it doesn't cancel.
The mechanics are easy, you should be able to spot the problem without much trouble. Not only can the tab on the ring wear, but also the tab on the turn signal lever that is being pushed. (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 15th January 2025 - 02:17 AM |
