> Challenge to anyone who knows-Still struggling with turn signals, cancel ring tab, turn signal operation
domer914
post Oct 25 2017, 11:55 AM
So I have discovered that the black tab on the cancel ring has zero bearing on turn signal cancellation. How the hell is that?
I have been troubleshooting the fact that left turn signals cancel, and right turn signals will not. So I discovered that I have this problem regardless of how the ring is installed. The black tab can sit at 12, 3, 6 or 9 o'clock, and right turn signals will not cancel, while left will.
arghhh
post Oct 25 2017, 01:12 PM
Resident German
Jack up the front of your car so both wheels are off the ground, only use the ring and hub without the steering wheel and see why it doesn't cancel.
The mechanics are easy, you should be able to spot the problem without much trouble.
Not only can the tab on the ring wear, but also the tab on the turn signal lever that is being pushed.
domer914
post Oct 25 2017, 01:23 PM
QUOTE(SirAndy @ Oct 25 2017, 02:12 PM) *
all my tabs (black on the cancel ring and white on the turn signal stalk) are brand new. This is a real head-shaker.
domer914   Challenge to anyone who knows-Still struggling with turn signals   Oct 25 2017, 11:55 AM
The Cabinetmaker   Are you referring to the ring on the steering whee...   Oct 25 2017, 12:16 PM
domer914   Are you referring to the ring on the steering whe...   Oct 25 2017, 01:05 PM
Elliot Cannon   The tab on the ring on the steering wheel can wear...   Oct 25 2017, 01:07 PM
Elliot Cannon   This one might work. https://www.ebay.com/itm/E...   Oct 25 2017, 01:11 PM
SirAndy   Jack up the front of your car so both wheels are o...   Oct 25 2017, 01:12 PM
domer914   Jack up the front of your car so both wheels are ...   Oct 25 2017, 01:23 PM
The Cabinetmaker   You need to look at the actual assembly mounted to...   Oct 25 2017, 01:13 PM
mzalanka   This is with the new turn signal switch you posted...   Oct 25 2017, 01:17 PM
domer914   This is with the new turn signal switch you poste...   Oct 25 2017, 01:24 PM
The Cabinetmaker   The 4 long screws that hold the switch to the colu...   Oct 25 2017, 01:31 PM
domer914   The 4 long screws that hold the switch to the col...   Oct 25 2017, 01:43 PM
The Cabinetmaker   It only works in one location. Unfortunately, I ca...   Oct 25 2017, 01:50 PM
Elliot Cannon   It only works in one location. Unfortunately, I c...   Oct 25 2017, 02:00 PM
The Cabinetmaker   Just slip the cancel ring on the shaft, engage the...   Oct 25 2017, 01:56 PM
SirAndy   Just slip the cancel ring on the shaft, engage the...   Oct 25 2017, 02:45 PM
The Cabinetmaker   Lol. I guess I should look to see who went with th...   Oct 25 2017, 02:02 PM
Jonathan Livesay   The tab on the steering wheel should be oriented s...   Oct 25 2017, 02:48 PM
mzalanka   Something is obviously not lining up to allow the ...   Oct 25 2017, 04:38 PM
Jonathan Livesay   Something is obviously not lining up to allow the...   Oct 25 2017, 09:20 PM
mzalanka   Yup, guess I have it right after all. Appreciate...   Oct 25 2017, 09:47 PM
domer914   okay. I'm certain that in my original post I ...   Oct 26 2017, 07:43 PM
Dave_Darling   okay. I'm certain that in my original post I...   Oct 27 2017, 09:35 AM
The Cabinetmaker   I'm extremely pleased that you got it fixed, a...   Oct 26 2017, 07:56 PM
domer914   I'm extremely pleased that you got it fixed, ...   Oct 26 2017, 08:24 PM
mepstein   I'm extremely pleased that you got it fixed,...   Oct 27 2017, 07:28 AM
theer   Furthermore, my wife calls me at work and she sa...   Oct 27 2017, 07:23 AM
mepstein   Furthermore, my wife calls me at work and she s...   Oct 27 2017, 07:27 AM
domer914   [quote name='theer' post='2542391' date='Oct 27 2...   Oct 27 2017, 08:27 AM
domer914   [quote name='theer' post='2542391' date='Oct 27 2...   Oct 28 2017, 07:44 AM
76-914   Occasionally one of these NOS OEM turn signal asse...   Oct 28 2017, 08:29 AM
Larmo63   If it works and you don't really know how you ...   Oct 28 2017, 01:31 PM
domer914   If it works and you don't really know how you...   Oct 29 2017, 09:08 AM
- Lo-Fi Version Time is now: 15th January 2025 - 02:03 AM
