> Challenge to anyone who knows-Still struggling with turn signals, cancel ring tab, turn signal operation
domer914
post Oct 25 2017, 11:55 AM
So I have discovered that the black tab on the cancel ring has zero bearing on turn signal cancellation. How the hell is that?
I have been troubleshooting the fact that left turn signals cancel, and right turn signals will not. So I discovered that I have this problem regardless of how the ring is installed. The black tab can sit at 12, 3, 6 or 9 o'clock, and right turn signals will not cancel, while left will.
arghhh
TheCabinetmaker
post Oct 25 2017, 01:31 PM
I drive my car everyday
The 4 long screws that hold the switch to the column can cause all sorts of problems if they are too tight.
domer914
post Oct 25 2017, 01:43 PM
QUOTE(The Cabinetmaker @ Oct 25 2017, 02:31 PM) *
thank you for that. Let's assume that I loosen them slightly and they are just right. Then at what location on a clock dial should the black tab on the cancel ring be located on the hub? Seems to me it should rest at 9 o'clock since the white tab is at 3 o'clock, but I don't really know.
domer914   Challenge to anyone who knows-Still struggling with turn signals   Oct 25 2017, 11:55 AM
The Cabinetmaker   Are you referring to the ring on the steering whee...   Oct 25 2017, 12:16 PM
domer914   Are you referring to the ring on the steering whe...   Oct 25 2017, 01:05 PM
Elliot Cannon   The tab on the ring on the steering wheel can wear...   Oct 25 2017, 01:07 PM
Elliot Cannon   This one might work. https://www.ebay.com/itm/E...   Oct 25 2017, 01:11 PM
SirAndy   Jack up the front of your car so both wheels are o...   Oct 25 2017, 01:12 PM
domer914   Jack up the front of your car so both wheels are ...   Oct 25 2017, 01:23 PM
The Cabinetmaker   You need to look at the actual assembly mounted to...   Oct 25 2017, 01:13 PM
mzalanka   This is with the new turn signal switch you posted...   Oct 25 2017, 01:17 PM
domer914   This is with the new turn signal switch you poste...   Oct 25 2017, 01:24 PM
The Cabinetmaker   The 4 long screws that hold the switch to the colu...   Oct 25 2017, 01:31 PM
domer914   The 4 long screws that hold the switch to the col...   Oct 25 2017, 01:43 PM
The Cabinetmaker   It only works in one location. Unfortunately, I ca...   Oct 25 2017, 01:50 PM
Elliot Cannon   It only works in one location. Unfortunately, I c...   Oct 25 2017, 02:00 PM
The Cabinetmaker   Just slip the cancel ring on the shaft, engage the...   Oct 25 2017, 01:56 PM
SirAndy   Just slip the cancel ring on the shaft, engage the...   Oct 25 2017, 02:45 PM
The Cabinetmaker   Lol. I guess I should look to see who went with th...   Oct 25 2017, 02:02 PM
Jonathan Livesay   The tab on the steering wheel should be oriented s...   Oct 25 2017, 02:48 PM
mzalanka   Something is obviously not lining up to allow the ...   Oct 25 2017, 04:38 PM
Jonathan Livesay   Something is obviously not lining up to allow the...   Oct 25 2017, 09:20 PM
mzalanka   Yup, guess I have it right after all. Appreciate...   Oct 25 2017, 09:47 PM
domer914   okay. I'm certain that in my original post I ...   Oct 26 2017, 07:43 PM
Dave_Darling   okay. I'm certain that in my original post I...   Oct 27 2017, 09:35 AM
The Cabinetmaker   I'm extremely pleased that you got it fixed, a...   Oct 26 2017, 07:56 PM
domer914   I'm extremely pleased that you got it fixed, ...   Oct 26 2017, 08:24 PM
mepstein   I'm extremely pleased that you got it fixed,...   Oct 27 2017, 07:28 AM
theer   Furthermore, my wife calls me at work and she sa...   Oct 27 2017, 07:23 AM
mepstein   Furthermore, my wife calls me at work and she s...   Oct 27 2017, 07:27 AM
domer914   [quote name='theer' post='2542391' date='Oct 27 2...   Oct 27 2017, 08:27 AM
domer914   [quote name='theer' post='2542391' date='Oct 27 2...   Oct 28 2017, 07:44 AM
76-914   Occasionally one of these NOS OEM turn signal asse...   Oct 28 2017, 08:29 AM
Larmo63   If it works and you don't really know how you ...   Oct 28 2017, 01:31 PM
domer914   If it works and you don't really know how you...   Oct 29 2017, 09:08 AM
22 User(s) are reading this topic (22 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 15th January 2025 - 02:21 AM
