> Challenge to anyone who knows-Still struggling with turn signals, cancel ring tab, turn signal operation
domer914
post Oct 25 2017, 11:55 AM
So I have discovered that the black tab on the cancel ring has zero bearing on turn signal cancellation. How the hell is that?
I have been troubleshooting the fact that left turn signals cancel, and right turn signals will not. So I discovered that I have this problem regardless of how the ring is installed. The black tab can sit at 12, 3, 6 or 9 o'clock, and right turn signals will not cancel, while left will.
arghhh
Jonathan Livesay
post Oct 25 2017, 02:48 PM
The tab on the steering wheel should be oriented so that it is directly opposite the turn signal lever when the front wheels are pointing straight ahead. If you have the wheel upside down on the workbench the tab would be at 9 o'clock.
mzalanka
post Oct 25 2017, 04:38 PM
Something is obviously not lining up to allow the R hand cancellation.
If you pull the wheel and watch the little white tab on the switch as you flip it L-R, you'll see that the white tab doesn't extend in the same place. On my (new) switch, it flips out and a little bit up for a L hand activation. With a R hand activation it extends down and not quite as far out.
L hand activation:
R hand activation:
I had the same problem with some turns not cancelling after installing the new turn signal switch. What worked for me was to use some loctite-brand plastic epoxy putty to "build up" the outside of the black semicircle on the steering wheel a few mm. That helped that plastic ring make contact with the white tab. Now it cancels fine all the time.
The other respondents are right that you'll need to fiddle with it and isolate the problem to figure out what's wrong with your setup.
FWIW - I have my black plastic ring installed at 3 o'clock. Maybe I should try reinstalling at 9 o'clock to see how that works.... (IMG:style_emoticons/default/unsure.gif)
Jonathan Livesay
post Oct 25 2017, 09:20 PM
QUOTE(mzalanka @ Oct 25 2017, 03:38 PM) *
I guess I wasn't clear enough, when the wheel is on the car the tab is at 3 o'clock, when it's upside down in your lap and you are attaching the ring it's 9 o'clock. Does that make sense?
mzalanka
post Oct 25 2017, 09:47 PM
Yup, guess I have it right after all. Appreciate the clarification. (IMG:style_emoticons/default/driving.gif)
domer914   Challenge to anyone who knows-Still struggling with turn signals   Oct 25 2017, 11:55 AM
The Cabinetmaker   Are you referring to the ring on the steering whee...   Oct 25 2017, 12:16 PM
domer914   Are you referring to the ring on the steering whe...   Oct 25 2017, 01:05 PM
Elliot Cannon   The tab on the ring on the steering wheel can wear...   Oct 25 2017, 01:07 PM
Elliot Cannon   This one might work. https://www.ebay.com/itm/E...   Oct 25 2017, 01:11 PM
SirAndy   Jack up the front of your car so both wheels are o...   Oct 25 2017, 01:12 PM
domer914   Jack up the front of your car so both wheels are ...   Oct 25 2017, 01:23 PM
The Cabinetmaker   You need to look at the actual assembly mounted to...   Oct 25 2017, 01:13 PM
mzalanka   This is with the new turn signal switch you posted...   Oct 25 2017, 01:17 PM
domer914   This is with the new turn signal switch you poste...   Oct 25 2017, 01:24 PM
The Cabinetmaker   The 4 long screws that hold the switch to the colu...   Oct 25 2017, 01:31 PM
domer914   The 4 long screws that hold the switch to the col...   Oct 25 2017, 01:43 PM
The Cabinetmaker   It only works in one location. Unfortunately, I ca...   Oct 25 2017, 01:50 PM
Elliot Cannon   It only works in one location. Unfortunately, I c...   Oct 25 2017, 02:00 PM
The Cabinetmaker   Just slip the cancel ring on the shaft, engage the...   Oct 25 2017, 01:56 PM
SirAndy   Just slip the cancel ring on the shaft, engage the...   Oct 25 2017, 02:45 PM
The Cabinetmaker   Lol. I guess I should look to see who went with th...   Oct 25 2017, 02:02 PM
Jonathan Livesay   The tab on the steering wheel should be oriented s...   Oct 25 2017, 02:48 PM
mzalanka   Something is obviously not lining up to allow the ...   Oct 25 2017, 04:38 PM
Jonathan Livesay   Something is obviously not lining up to allow the...   Oct 25 2017, 09:20 PM
mzalanka   Yup, guess I have it right after all. Appreciate...   Oct 25 2017, 09:47 PM
domer914   okay. I'm certain that in my original post I ...   Oct 26 2017, 07:43 PM
Dave_Darling   okay. I'm certain that in my original post I...   Oct 27 2017, 09:35 AM
The Cabinetmaker   I'm extremely pleased that you got it fixed, a...   Oct 26 2017, 07:56 PM
domer914   I'm extremely pleased that you got it fixed, ...   Oct 26 2017, 08:24 PM
mepstein   I'm extremely pleased that you got it fixed,...   Oct 27 2017, 07:28 AM
theer   Furthermore, my wife calls me at work and she sa...   Oct 27 2017, 07:23 AM
mepstein   Furthermore, my wife calls me at work and she s...   Oct 27 2017, 07:27 AM
domer914   [quote name='theer' post='2542391' date='Oct 27 2...   Oct 27 2017, 08:27 AM
domer914   [quote name='theer' post='2542391' date='Oct 27 2...   Oct 28 2017, 07:44 AM
76-914   Occasionally one of these NOS OEM turn signal asse...   Oct 28 2017, 08:29 AM
Larmo63   If it works and you don't really know how you ...   Oct 28 2017, 01:31 PM
domer914   If it works and you don't really know how you...   Oct 29 2017, 09:08 AM
13 User(s) are reading this topic (13 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 15th January 2025 - 02:15 AM
