L-Jet Auxillary Air Regulator or Valve?, Proper operation of the AAR |
malcolm2 |
Oct 17 2017, 12:38 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I found an very old, very short post about the subject and cleaning the AAR with PB Blaster. So I guess I'll try that. But that post did not answer my current problem.
I have had my AAR off of my car and the hose connections plugged for about 6 months now. But it is getting cold and it has been recommended that I put it back in service. So I tested it. And took some pictures along the way. I did the FREEZER test and it opened. I sat it in the sun. Very warm exterior case. Kinda tuff to hold it. It absorbed a good bit of heat.... and almost closed. Then I broke out my handy dandy 12v drill battery and within a few seconds it was closed. here is the question..... I tried to blow thru the closed hole and had ZERO problem doing that. So I suppose when closed that NO AIR should pass thru, correct? Will the PB Blaster cleaning help, or is this baby done for? Any ideas on fixing? Thanks. |
DRPHIL914 |
Oct 19 2017, 08:10 AM
Dr. Phil Group: Members Posts: 5,810 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I have one of those that I bought a long time ago by accident- I have d-jet and have a perfectly functioning d-jet NOS one I installed. -
if you need one let me know- I can send this one your way- you can pay me once you get it and test it to make sure it works- its been in a box on my shelf for a few years, but it was tested as fully functioning 5 years ago. Phil |
malcolm2 |
Oct 19 2017, 10:47 AM
I have one of those that I bought a long time ago by accident- I have d-jet and have a perfectly functioning d-jet NOS one I installed. - if you need one let me know- I can send this one your way- you can pay me once you get it and test it to make sure it works- its been in a box on my shelf for a few years, but it was tested as fully functioning 5 years ago. Phil PM sent... |
DRPHIL914 |
Oct 26 2017, 10:52 AM
I have one of those that I bought a long time ago by accident- I have d-jet and have a perfectly functioning d-jet NOS one I installed. - if you need one let me know- I can send this one your way- you can pay me once you get it and test it to make sure it works- its been in a box on my shelf for a few years, but it was tested as fully functioning 5 years ago. Phil PM sent... on its way let me know if it works. it should arrive saturday |
Lo-Fi Version | Time is now: 27th December 2024 - 10:06 AM |
