> Challenge to anyone who knows-Still struggling with turn signals, cancel ring tab, turn signal operation
domer914
post Oct 25 2017, 11:55 AM
So I have discovered that the black tab on the cancel ring has zero bearing on turn signal cancellation. How the hell is that?
I have been troubleshooting the fact that left turn signals cancel, and right turn signals will not. So I discovered that I have this problem regardless of how the ring is installed. The black tab can sit at 12, 3, 6 or 9 o'clock, and right turn signals will not cancel, while left will.
arghhh
domer914
post Oct 26 2017, 07:43 PM
okay. I'm certain that in my original post I explained that I am an idiot. If I were inclined I would have explained how I always spend twice the time and twice the money that anyone would who is NOT an idiot. I learn all my lessons the hard and expensive way, it seems.
Anyway, my right signal would not cancel. My parts were old, and I decided to buy new washer arm and new turn signal stalk.
So I dick around with the wiper arm and end up breaking plastic pieces on it as I attempt to adapt it to my car (it was not identical to the one pulled off my car). So I decide to marry the new turn signal arm to the old wiper arm.
I hook it up. Horn doesn't work. It worked before. Signal still does not cancel. Furthermore, my wife calls me at work and she says she thinks the right rear brake light is on on my 914. I rush out of the office, get home and disconnect the wiring harness to the two stalks and the light goes out. Hook a trickle charger to the battery just in case, and I return to work.
Tonight I decide to ditch the new part and re-install the old parts.
Everything works. Turn signals cancel. Problem solved. No net changes (except perhaps the location of the cancelling tab on the wheel). $130 spent and probably 4 hours of my time. And I have essentially ruined $70 of the parts I acquired.
sigh.
sigh again.
I am grateful to the forum for all the input. It was helpful, and inspirational. People like me need inspiration.
Dave_Darling
post Oct 27 2017, 09:35 AM
914 Idiot
QUOTE(domer914 @ Oct 26 2017, 06:43 PM) *
Do that for a few more years, then decide that everyone else can benefit from your opinions and experiences, and you can be a bona-fide 914 Expert!
... Welcome to the club, Domer. (IMG:style_emoticons/default/smile.gif)
--DD
domer914   Challenge to anyone who knows-Still struggling with turn signals   Oct 25 2017, 11:55 AM
The Cabinetmaker   Are you referring to the ring on the steering whee...   Oct 25 2017, 12:16 PM
domer914   Are you referring to the ring on the steering whe...   Oct 25 2017, 01:05 PM
Elliot Cannon   The tab on the ring on the steering wheel can wear...   Oct 25 2017, 01:07 PM
Elliot Cannon   This one might work. https://www.ebay.com/itm/E...   Oct 25 2017, 01:11 PM
SirAndy   Jack up the front of your car so both wheels are o...   Oct 25 2017, 01:12 PM
domer914   Jack up the front of your car so both wheels are ...   Oct 25 2017, 01:23 PM
The Cabinetmaker   You need to look at the actual assembly mounted to...   Oct 25 2017, 01:13 PM
mzalanka   This is with the new turn signal switch you posted...   Oct 25 2017, 01:17 PM
domer914   This is with the new turn signal switch you poste...   Oct 25 2017, 01:24 PM
The Cabinetmaker   The 4 long screws that hold the switch to the colu...   Oct 25 2017, 01:31 PM
domer914   The 4 long screws that hold the switch to the col...   Oct 25 2017, 01:43 PM
The Cabinetmaker   It only works in one location. Unfortunately, I ca...   Oct 25 2017, 01:50 PM
Elliot Cannon   It only works in one location. Unfortunately, I c...   Oct 25 2017, 02:00 PM
The Cabinetmaker   Just slip the cancel ring on the shaft, engage the...   Oct 25 2017, 01:56 PM
SirAndy   Just slip the cancel ring on the shaft, engage the...   Oct 25 2017, 02:45 PM
The Cabinetmaker   Lol. I guess I should look to see who went with th...   Oct 25 2017, 02:02 PM
Jonathan Livesay   The tab on the steering wheel should be oriented s...   Oct 25 2017, 02:48 PM
mzalanka   Something is obviously not lining up to allow the ...   Oct 25 2017, 04:38 PM
Jonathan Livesay   Something is obviously not lining up to allow the...   Oct 25 2017, 09:20 PM
mzalanka   Yup, guess I have it right after all. Appreciate...   Oct 25 2017, 09:47 PM
domer914   okay. I'm certain that in my original post I ...   Oct 26 2017, 07:43 PM
Dave_Darling   okay. I'm certain that in my original post I...   Oct 27 2017, 09:35 AM
The Cabinetmaker   I'm extremely pleased that you got it fixed, a...   Oct 26 2017, 07:56 PM
domer914   I'm extremely pleased that you got it fixed, ...   Oct 26 2017, 08:24 PM
mepstein   I'm extremely pleased that you got it fixed,...   Oct 27 2017, 07:28 AM
theer   Furthermore, my wife calls me at work and she sa...   Oct 27 2017, 07:23 AM
mepstein   Furthermore, my wife calls me at work and she s...   Oct 27 2017, 07:27 AM
domer914   [quote name='theer' post='2542391' date='Oct 27 2...   Oct 27 2017, 08:27 AM
domer914   [quote name='theer' post='2542391' date='Oct 27 2...   Oct 28 2017, 07:44 AM
76-914   Occasionally one of these NOS OEM turn signal asse...   Oct 28 2017, 08:29 AM
Larmo63   If it works and you don't really know how you ...   Oct 28 2017, 01:31 PM
domer914   If it works and you don't really know how you...   Oct 29 2017, 09:08 AM
18 User(s) are reading this topic (18 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 15th January 2025 - 02:17 AM
