23 mm Master cylinder?, From a 930? |
HalfMoon |
Oct 31 2017, 08:46 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
A friend of mine who owns a race shop that does alot of Porsche work said when queried about reducing travel on the 914 brake system that the 23mm master cylinder from a 930 would far better reduce the travel over a 19mm master cylinder.
Has anyone done this mod and if so, what were the performance gains/differences? Thanks D |
shoguneagle |
Oct 31 2017, 10:52 PM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
Agree with all the above. I am running 23mm M/C with Carrera brakes; very stiff pedal which what I like; can put you through the windshield as Mike as stated; requires a strong leg pressure; 19mm would work with my setup but I do not like the pedal (had it on prior to 23mm).
HalfMoon |
Oct 31 2017, 10:57 PM
Agree with all the above. I am running 23mm M/C with Carrera brakes; very stiff pedal which what I like; can put you through the windshield as Mike as stated; requires a strong leg pressure; 19mm would work with my setup but I do not like the pedal (had it on prior to 23mm). Again, thank you for your real world experience report. |
Lo-Fi Version | Time is now: 26th December 2024 - 09:34 PM |
