23 mm Master cylinder?, From a 930? |
HalfMoon |
Oct 31 2017, 08:46 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
A friend of mine who owns a race shop that does alot of Porsche work said when queried about reducing travel on the 914 brake system that the 23mm master cylinder from a 930 would far better reduce the travel over a 19mm master cylinder.
Has anyone done this mod and if so, what were the performance gains/differences? Thanks D |
infraredcalvin |
Oct 31 2017, 11:50 PM
Distracted Member Group: Members Posts: 1,575 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
It’s not a 930 MC is a 23 mm ATE MC for a Mercedes, the 930 23 mm MC is for power assisted brakes. I did the conversion on my early 930, replaced the aluminum s brakes and stock 19 mm MC for turbo brakes and the 23 mm MC. It’s stiff with the 930 brakes, I wouldn’t want it on anything less, as for travel, yes less travel, but more pressure to achieve the same results. I also had to fab a spacer as the rod actuator needs to be longer to work on the 23 mm MC.
I can heel toe on about anything, but I always found it easier when there’s a bit more travel on the brake... You can also adjust the pedal lower to reduce overall travel... (Edited again after MC size confirmation) (IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 26th December 2024 - 09:04 PM |
