23 mm Master cylinder?, From a 930? |
HalfMoon |
Oct 31 2017, 08:46 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
A friend of mine who owns a race shop that does alot of Porsche work said when queried about reducing travel on the 914 brake system that the 23mm master cylinder from a 930 would far better reduce the travel over a 19mm master cylinder.
Has anyone done this mod and if so, what were the performance gains/differences? Thanks D |
HalfMoon |
Oct 31 2017, 10:55 PM
To clarify-
I run a 19mm too (as well as a variety of other big brake mods). The primary question I'm pursuing isn't brake "power" (performance gains/differences is/was ancillary), rather it's about "less pedal travel". That's what the inquiry is really about as well as the advice I had been given. So I guess the question is for folks who have ACTUALLY done the modification to a 23mm and if they have obtained less pedal travel as a result. Not asking about theory or opinion, asking about actual experience. Many of us have done the 19mm change and their's reams of information on that mod but not much about the 23mm and pretty much nothing in terms of actual experience. The main thrust of the question is "brake travel". |
mepstein |
Nov 1 2017, 05:30 AM
914-6 GT in waiting Group: Members Posts: 19,649 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
To clarify- I run a 19mm too (as well as a variety of other big brake mods). The primary question I'm pursuing isn't brake "power" (performance gains/differences is/was ancillary), rather it's about "less pedal travel". That's what the inquiry is really about as well as the advice I had been given. So I guess the question is for folks who have ACTUALLY done the modification to a 23mm and if they have obtained less pedal travel as a result. Not asking about theory or opinion, asking about actual experience. Many of us have done the 19mm change and their's reams of information on that mod but not much about the 23mm and pretty much nothing in terms of actual experience. The main thrust of the question is "brake travel". The change in pressure and travel when you go to a larger MC isn't theory or opinion. Its a relationship/ratio between the size of the MC and size of the piston calipers. If you keep the calipers the same but increase the size of the MC, the MC will move more fluid with less pedal travel but at the same time, you will need more pressure on the pedal to achieve the same braking force at the caliper. Just like sitting on a see saw, shorten the lever on your side and it gets harder to lift the other end but the travel on your end is shorter. Go too short and at some point, you don't have the force available to move the lever. You also have to make sure the ratio front to back is correct. Its not just about going big, it's about the correct balance. You won't see much information on World about 23mm MC's because most of the cars simply can't use a MC that large unless they've also switched to very large calipers. |
HalfMoon |
Nov 1 2017, 10:02 AM
To clarify- I run a 19mm too (as well as a variety of other big brake mods). The primary question I'm pursuing isn't brake "power" (performance gains/differences is/was ancillary), rather it's about "less pedal travel". That's what the inquiry is really about as well as the advice I had been given. So I guess the question is for folks who have ACTUALLY done the modification to a 23mm and if they have obtained less pedal travel as a result. Not asking about theory or opinion, asking about actual experience. Many of us have done the 19mm change and their's reams of information on that mod but not much about the 23mm and pretty much nothing in terms of actual experience. The main thrust of the question is "brake travel". The change in pressure and travel when you go to a larger MC isn't theory or opinion. Its a relationship/ratio between the size of the MC and size of the piston calipers. If you keep the calipers the same but increase the size of the MC, the MC will move more fluid with less pedal travel but at the same time, you will need more pressure on the pedal to achieve the same braking force at the caliper. Just like sitting on a see saw, shorten the lever on your side and it gets harder to lift the other end but the travel on your end is shorter. Go too short and at some point, you don't have the force available to move the lever. You also have to make sure the ratio front to back is correct. Its not just about going big, it's about the correct balance. You won't see much information on World about 23mm MC's because most of the cars simply can't use a MC that large unless they've also switched to very large calipers. Yep, already knew all that thanks. So, have you done the conversion and have actual road experience with same and if so did it reduce your brake travel? |
Lo-Fi Version | Time is now: 26th December 2024 - 08:44 PM |
