> Need Help On 6 Manual Throttle Please, Pics would be really great!
Lucky9146
post Oct 31 2017, 09:19 PM
Received my Manual throttle assembly from 914 Rubber and it looks great! But no specific instruction regarding the “Shark Fin” and I have not seen a real one up close. I understand where and how the lever and rod go that's no problem.
Did some poking around here on the site (IMG:style_emoticons/default/type.gif) where I thought I might see pictures but I did not see the small “shark fin” and how and where exactly it goes on the gas pedal. (IMG:style_emoticons/default/idea.gif)
Does anybody have a good picture of the "Shark Fin" installed either real original 914-6 or 914 Rubber version?
Of course I had just got all the pedal cables hooked up and adjusted when I received the assembly not understanding how the hand throttle actually worked. I’m thinking the whole pedal assembly has to come out. (IMG:style_emoticons/default/confused24.gif)
“Shark Fin” is on the far left. Thanks!
(IMG:style_emoticons/default/white914.jpg)
horizontally-opposed
post Nov 1 2017, 11:08 AM
This looks like a great product, and I am very interested.
Curious, however, on why the kit requires welding the shark fin onto the crank, and then presumably having said crank restored and replated? Why not make that an option? I am guessing a lot of customers would happily pay for it? In fact, I'd rather have that and the rod assembly without the kit's lever—as I already have one of those.
As always, however, 914rubber's contribution to the hobby is more than appreciated. How great that this kit exists at all?
Lucky9146   Need Help On 6 Manual Throttle Please   Oct 31 2017, 09:19 PM
Mikey914   You for a install without welding, you can drill 2...   Oct 31 2017, 09:35 PM
raynekat   Here's the "shark fin" welded on to ...   Nov 1 2017, 12:47 AM
Lucky9146   Here's the "shark fin" welded on to...   Nov 1 2017, 10:52 AM
porschetub   Received my Manual throttle assembly from 914 Rub...   Nov 1 2017, 02:13 AM
Lucky9146   Received my Manual throttle assembly from 914 Ru...   Nov 1 2017, 11:01 AM
horizontally-opposed   This looks like a great product, and I am very int...   Nov 1 2017, 11:08 AM
Lucky9146   This looks like a great product, and I am very in...   Nov 1 2017, 11:25 AM
SixerJ   Here you go, I tucked the corner of the wood templ...   Nov 1 2017, 11:34 AM
rgalla9146   Here you go, I tucked the corner of the wood temp...   Nov 1 2017, 11:57 AM
Lucky9146   Here you go, I tucked the corner of the wood temp...   Nov 1 2017, 01:47 PM
gandalf_025   here it is on a complete assembly.   Nov 1 2017, 11:48 AM
horizontally-opposed   Bruce Anderson used to talk about how he loved to ...   Nov 1 2017, 12:38 PM
Larmo63   Just for kicks, this is my set up. Genuine 914-6 s...   Nov 1 2017, 12:49 PM
Lucky9146   Just for kicks, this is my set up. Genuine 914-6 ...   Nov 1 2017, 01:55 PM
Mikey914   Here's the drawing I have. We colorized if on ...   Nov 1 2017, 01:03 PM
Larmo63   I like the look of the shifter bolted over the car...   Nov 1 2017, 03:13 PM
Lucky9146   I like the look of the shifter bolted over the ca...   Nov 1 2017, 03:29 PM
mb911   Just send me the fins and I will weld them on quic...   Nov 1 2017, 05:44 PM
horizontally-opposed   Just send me the fins and I will weld them on qui...   Nov 1 2017, 06:41 PM
Lucky9146   Just send me the fins and I will weld them on qui...   Nov 2 2017, 10:10 PM
Larmo63   There is really not that much pressure on pushing ...   Nov 1 2017, 07:48 PM
SixerJ   There is really not that much pressure on pushing...   Nov 2 2017, 01:40 AM
Mikey914   I have been working with Bruce Stone on these. whe...   Nov 2 2017, 10:05 AM
Lucky9146   Update! Was able to surgically extract the le...   Nov 2 2017, 11:08 PM
SixerJ   Jim here you go. As you can see the fin is not har...   Nov 3 2017, 01:47 AM
Lucky9146   Jim here you go. As you can see the fin is not ha...   Nov 3 2017, 09:23 AM
SixerJ   RE: Need Help On 6 Manual Throttle Please   Nov 3 2017, 01:48 AM
- Lo-Fi Version Time is now: 19th April 2025 - 06:34 PM
