> Need Help On 6 Manual Throttle Please, Pics would be really great!
Lucky9146
post Oct 31 2017, 09:19 PM
Received my Manual throttle assembly from 914 Rubber and it looks great! But no specific instruction regarding the “Shark Fin” and I have not seen a real one up close. I understand where and how the lever and rod go that's no problem.
Did some poking around here on the site (IMG:style_emoticons/default/type.gif) where I thought I might see pictures but I did not see the small “shark fin” and how and where exactly it goes on the gas pedal. (IMG:style_emoticons/default/idea.gif)
Does anybody have a good picture of the "Shark Fin" installed either real original 914-6 or 914 Rubber version?
Of course I had just got all the pedal cables hooked up and adjusted when I received the assembly not understanding how the hand throttle actually worked. I’m thinking the whole pedal assembly has to come out. (IMG:style_emoticons/default/confused24.gif)
“Shark Fin” is on the far left. Thanks!
(IMG:style_emoticons/default/white914.jpg)
horizontally-opposed
post Nov 1 2017, 12:38 PM
Bruce Anderson used to talk about how he loved to use the hand throttle in his 914-6 as cruise control on long trips. While my car starts up cold pretty nicely, my last trip to LA got me thinking about adding this upgrade...
Lucky9146   Need Help On 6 Manual Throttle Please   Oct 31 2017, 09:19 PM
Mikey914   You for a install without welding, you can drill 2...   Oct 31 2017, 09:35 PM
raynekat   Here's the "shark fin" welded on to ...   Nov 1 2017, 12:47 AM
Lucky9146   Here's the "shark fin" welded on to...   Nov 1 2017, 10:52 AM
porschetub   Received my Manual throttle assembly from 914 Rub...   Nov 1 2017, 02:13 AM
Lucky9146   Received my Manual throttle assembly from 914 Ru...   Nov 1 2017, 11:01 AM
horizontally-opposed   This looks like a great product, and I am very int...   Nov 1 2017, 11:08 AM
Lucky9146   This looks like a great product, and I am very in...   Nov 1 2017, 11:25 AM
SixerJ   Here you go, I tucked the corner of the wood templ...   Nov 1 2017, 11:34 AM
rgalla9146   Here you go, I tucked the corner of the wood temp...   Nov 1 2017, 11:57 AM
Lucky9146   Here you go, I tucked the corner of the wood temp...   Nov 1 2017, 01:47 PM
gandalf_025   here it is on a complete assembly.   Nov 1 2017, 11:48 AM
horizontally-opposed   Bruce Anderson used to talk about how he loved to ...   Nov 1 2017, 12:38 PM
Larmo63   Just for kicks, this is my set up. Genuine 914-6 s...   Nov 1 2017, 12:49 PM
Lucky9146   Just for kicks, this is my set up. Genuine 914-6 ...   Nov 1 2017, 01:55 PM
Mikey914   Here's the drawing I have. We colorized if on ...   Nov 1 2017, 01:03 PM
Larmo63   I like the look of the shifter bolted over the car...   Nov 1 2017, 03:13 PM
Lucky9146   I like the look of the shifter bolted over the ca...   Nov 1 2017, 03:29 PM
mb911   Just send me the fins and I will weld them on quic...   Nov 1 2017, 05:44 PM
horizontally-opposed   Just send me the fins and I will weld them on qui...   Nov 1 2017, 06:41 PM
Lucky9146   Just send me the fins and I will weld them on qui...   Nov 2 2017, 10:10 PM
Larmo63   There is really not that much pressure on pushing ...   Nov 1 2017, 07:48 PM
SixerJ   There is really not that much pressure on pushing...   Nov 2 2017, 01:40 AM
Mikey914   I have been working with Bruce Stone on these. whe...   Nov 2 2017, 10:05 AM
Lucky9146   Update! Was able to surgically extract the le...   Nov 2 2017, 11:08 PM
SixerJ   Jim here you go. As you can see the fin is not har...   Nov 3 2017, 01:47 AM
Lucky9146   Jim here you go. As you can see the fin is not ha...   Nov 3 2017, 09:23 AM
SixerJ   RE: Need Help On 6 Manual Throttle Please   Nov 3 2017, 01:48 AM
- Lo-Fi Version Time is now: 19th April 2025 - 06:32 PM
