23 mm Master cylinder?, From a 930? |
HalfMoon |
Oct 31 2017, 08:46 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
A friend of mine who owns a race shop that does alot of Porsche work said when queried about reducing travel on the 914 brake system that the 23mm master cylinder from a 930 would far better reduce the travel over a 19mm master cylinder.
Has anyone done this mod and if so, what were the performance gains/differences? Thanks D |
Dave_Darling |
Nov 1 2017, 09:48 PM
914 Idiot Group: Members Posts: 15,063 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
When you change the diameter of the master cylinder, you are changing the hydraulic advantage over the brake pads. The effect is almost exactly the same as shortening the arm on the pedal. You get less travel but you have to push harder for the same clamping force.
--DD |
SirAndy |
Nov 2 2017, 11:19 AM
Resident German Group: Admin Posts: 41,945 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
When you change the diameter of the master cylinder, you are changing the hydraulic advantage over the brake pads. The effect is almost exactly the same as shortening the arm on the pedal. You get less travel but you have to push harder for the same clamping force. To quote my girlfriend: "How dare you bring logic into this argument!" (IMG:style_emoticons/default/biggrin.gif) As for real world experience, i settled for a 19mm MC after replacing the 930 brakes with Boxster brakes. I prefer the slightly longer travel and less pressure needed as it allows for better brake modulation. My opinion, based on actual real life experience ... (IMG:style_emoticons/default/shades.gif) PS: And i too can put your head through the windshield. Not sure why this is quoted as a positive "must have" but i can easily provide that, if needed. |
Lo-Fi Version | Time is now: 26th December 2024 - 09:26 PM |
