> 23 mm Master cylinder?, From a 930?
HalfMoon
post Oct 31 2017, 08:46 PM
A friend of mine who owns a race shop that does alot of Porsche work said when queried about reducing travel on the 914 brake system that the 23mm master cylinder from a 930 would far better reduce the travel over a 19mm master cylinder.
Has anyone done this mod and if so, what were the performance gains/differences?
Thanks
D
ChrisFoley
post Nov 1 2017, 09:04 AM
I am Tangerine Racing
We just swapped out a 23mm M/C for a 22 mm VW unit in a V8 track car we have here with BIG brakes.
I thought the pedal could be modulated fine, with good toe-heel control for downshifts, but the owner wanted it to be a little easier on his leg.
The other option was to install a vacuum brake booster but that would have been more work.
mgp4591
post Nov 1 2017, 11:05 AM
QUOTE(Racer Chris @ Nov 1 2017, 09:04 AM) *
Is that the M/C for the Corrado that you swapped for? I've heard good things about those being a workable compromise between the 19mm and the 23mm. I'm running the 944T calipers all around and was thinking it would be a good option for occasional track use besides street functions.
ChrisFoley
post Nov 1 2017, 11:07 AM
QUOTE(mgp4591 @ Nov 1 2017, 01:05 PM) *
Yes, but I haven't driven the car yet to see how it feels.
tomeric914
post Nov 1 2017, 07:03 PM
One Lap of America in a 914!
20.64mm or 22.22mm Master Cylinder Option How-To thread is in my signature. Yes, I've driven it on track and yes it feels much better given my brake setup.
http://www.914world.com/bbs2/index.php?showtopic=312451
QUOTE(Racer Chris @ Nov 1 2017, 01:07 PM) *
HalfMoon
post Nov 2 2017, 05:38 PM
QUOTE(tomeric914 @ Nov 1 2017, 09:03 PM) *
WOW!
No that is some cool intel.
Thanks a bunch for sharing that.
I know you did the 20.64, but what's your thought on reduction of pedal throw using the 22.22 and other than cost, what would the advantage be over the 930 23mm? Do you think the 22.22 is slightly less stiff than the 23?
David
tomeric914
post Nov 2 2017, 07:54 PM
David,
This is basic hydraulics, but somehow, too many internet "car gurus" screw this up. Bigger isn't better.
A larger diameter master cylinder alone will move more fluid but require more foot pressure to affect brake force value X.
A smaller diameter master cylinder will move less fluid but require less foot pressure to affect the same brake force value X.
It is important to get the ratio correct which requires some calculation involving the lever arm of the pedal assembly to the master cylinder as well as all of the piston sizes in the system being acted upon.
914s came from the factory with a 17mm master cylinder which some perceive as squishy. The next step up is a 19mm from a 911 which makes the pedal firmer but harder to push. Some like that feeling because the brakes are "right there". Jumping to a 23.8mm master cylinder in a stock 914 (for example) would result in an extremely hard pedal that would be very difficult to modulate. You would also need some beefy calf muscles to operate the brakes.
My write up opens the door for even more master cylinder / caliper combinations so that we don't have to jump from a 19mm to a 23.8mm in our little P cars.
For a little help on what combinations work, reference Bill Verberg's brake page to see the combinations that the Porsche factory used.
https://members.rennlist.com/1976c38/brakes.htm
QUOTE(HalfMoon @ Nov 2 2017, 07:38 PM) *
WOW!
David
HalfMoon
post Nov 2 2017, 11:48 PM
QUOTE(tomeric914 @ Nov 2 2017, 09:54 PM) *
David,
WOW!
David
Well I can certainly agree with the idea that bigger doesn't necessarily mean better. I think many poster have missed the point of the original post. Perhaps if I put it in caps?
THIS THREAD IS ABOUT REDUCING BRAKE THROW.
Yes, I understand and have understood what this entails (more leg power). It's about thinking out of the box and finding a balance. My brakes are not stock and they do a fine job. I'm trying to find a master cylinder size that can reduce throw yet still have some modulation ability. I currently run a 19mm and find that their's still way to much throw for my taste. I had heard the 23mm out of a 930 would reduce the throw considerably, but some real world reporting is indicating difficulty modulating. Seems like the 22.22 might be a good compromise.
tomeric914
post Nov 3 2017, 03:04 PM
THIS IS AN EXAMPLE ONLY!!! You need to do the math for your vehicle.
You could calculate it and determine which is best.
Here are the exact sizes available:
You'll need to determine the stroke that you have by simply measuring how far the piston is pushed into the current master cylinder. Then determine how much reduction in stroke you want. THIS IS STROKE ONLY NOT PEDAL TRAVEL. You'll need to calculate your pedal ratio to determine travel.
We're basically calculating the volume of fluid moved. So, for example:
19mm M/C D = .750"
Current stroke h = .625"
V = pi * (D/2)^2 * h
V = 3.14 * (.750" / 2)^2 * .625"
V = .2759766 in^3
So if we want to reduce the stroke by .125", but move the same volume, we solve for the diameter:
D = 2 * ((V / pi / h)^0.5)
D = 2 * (((.275966 / 3.14 / (.625" - .125"))^0.5)
D = .8385"
This result falls closer to the 20.64mm master cylinder
For pedal travel:
A = Distance from pivot point to middle of push / pull point
B = Distance from pivot to point of push on master cylinder
P = Pivot point
Pedal Ratio is determined by dividing length "A" by length "B"
Pedal travel = M/C stroke * Pedal Ratio
(I recall the 914 brake pedal ratio being something like 5.4 to 1)
QUOTE(HalfMoon @ Nov 3 2017, 01:48 AM) *
...I currently run a 19mm and find that their's still way to much throw for my taste. I had heard the 23mm out of a 930 would reduce the throw considerably, but some real world reporting is indicating difficulty modulating. Seems like the 22.22 might be a good compromise.
HalfMoon   23 mm Master cylinder?   Oct 31 2017, 08:46 PM
Vacca Rabite   A friend of mine who owns a race shop that does a...   Oct 31 2017, 09:32 PM
HalfMoon   A friend of mine who owns a race shop that does ...   Oct 31 2017, 10:05 PM
porschetub   A friend of mine who owns a race shop that does a...   Oct 31 2017, 10:19 PM
Mike Bellis   I'm running a 23 but I also have 930 brakes. I...   Oct 31 2017, 10:39 PM
HalfMoon   I'm running a 23 but I also have 930 brakes. ...   Oct 31 2017, 10:56 PM
shoguneagle   Agree with all the above. I am running 23mm M/C w...   Oct 31 2017, 10:52 PM
HalfMoon   Agree with all the above. I am running 23mm M/C ...   Oct 31 2017, 10:57 PM
HalfMoon   To clarify- I run a 19mm too (as well as a variet...   Oct 31 2017, 10:55 PM
mepstein   To clarify- I run a 19mm too (as well as a varie...   Nov 1 2017, 05:30 AM
jd74914   To clarify- I run a 19mm too (as well as a vari...   Nov 1 2017, 05:49 AM
mepstein   [quote name='mepstein' post='2544209' date='Nov 1...   Nov 1 2017, 05:58 AM
HalfMoon   To clarify- I run a 19mm too (as well as a vari...   Nov 1 2017, 10:02 AM
mepstein   [quote name='mepstein' post='2544209' date='Nov 1...   Nov 1 2017, 11:36 AM
porschetub   [quote name='mepstein' post='2544209' date='Nov ...   Nov 1 2017, 04:59 PM
infraredcalvin   It’s not a 930 MC is a 23 mm ATE MC for a Merced...   Oct 31 2017, 11:50 PM
infraredcalvin   Sorry had to edit above...   Oct 31 2017, 11:55 PM
flyer86d   My old 911SC track car had turbo brakes front and ...   Nov 1 2017, 05:30 AM
DBCooper   And, important to note, with just a larger m/c you...   Nov 1 2017, 08:28 AM
Racer Chris   We just swapped out a 23mm M/C for a 22 mm VW unit...   Nov 1 2017, 09:04 AM
HalfMoon   We just swapped out a 23mm M/C for a 22 mm VW uni...   Nov 1 2017, 10:05 AM
mgp4591   We just swapped out a 23mm M/C for a 22 mm VW uni...   Nov 1 2017, 11:05 AM
Racer Chris   Is that the M/C for the Corrado that you swapped ...   Nov 1 2017, 11:07 AM
tomeric914   20.64mm or 22.22mm Master Cylinder Option How-To t...   Nov 1 2017, 07:03 PM
HalfMoon   20.64mm or 22.22mm Master Cylinder Option How-To ...   Nov 2 2017, 05:38 PM
Racer Chris   20.64mm or 22.22mm Master Cylinder Option How-To...   Nov 2 2017, 07:08 PM
tomeric914   David, This is basic hydraulics, but somehow, too...   Nov 2 2017, 07:54 PM
HalfMoon   David, This is basic hydraulics, but somehow, to...   Nov 2 2017, 11:48 PM
Keyser Sose   I currently run a 19mm and find that their's s...   Nov 3 2017, 10:56 AM
Racer Chris   the bias valve can make it hard to get them full...   Nov 3 2017, 03:03 PM
Keyser Sose   the bias valve can make it hard to get them ful...   Nov 3 2017, 03:37 PM
Racer Chris   So do those valves ever go bad? They don't ...   Nov 4 2017, 09:06 AM
tomeric914   THIS IS AN EXAMPLE ONLY!!! You need t...   Nov 3 2017, 03:04 PM
DBCooper   OK, when I got my car the pedal was way too hard. ...   Nov 1 2017, 10:34 AM
Dave_Darling   When you change the diameter of the master cylinde...   Nov 1 2017, 09:48 PM
tomeric914   ...on a bone stock brake system When you change ...   Nov 2 2017, 08:39 AM
Dave_Darling   ...on a bone stock brake system No, that's ...   Nov 2 2017, 12:07 PM
tomeric914   The reason for going with a larger master cylinder...   Nov 2 2017, 07:36 PM
SirAndy   When you change the diameter of the master cylinde...   Nov 2 2017, 11:19 AM
porschetub   When you change the diameter of the master cylind...   Nov 2 2017, 06:59 PM
GeorgeRud   Is the lack of a proportioning valve on the 911s b...   Nov 4 2017, 09:19 AM
10 User(s) are reading this topic (10 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 26th December 2024 - 09:35 PM
