Easy as 1 2 3, Got it yesterday, pushed all projects aside! |
mgphoto |
Sep 28 2017, 03:54 PM
"If there is a mistake it will find me" Group: Members Posts: 1,366 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Got the 123Ignition yesterday, I pushed all of my projects back!
"Sorry granny I'll get to those bearings on your heart/lung machine soon, I promise." Blocked out 3 hours for the removal and install. Added about an hour to charge the battery. Installed as expected, there is a spacer that is necessary for type 4, just slides over the dizzy shaft. I decided to route the wires and vacuum away from the fan so access to the vacuum nipple was easier, since the vacuum can is gone there's a lot more space. Followed the instructions but made the mistake of using the TDC 0* instead of the 27* as the basic timing point. I just walked the dizzy CCW until she started! Didn't do anything other than matched my timing with my idle, I let her run till she settled down. Just around the block once, ha ha the trailer hitching is GONE! Responsive throttle, man! Setting up a tuning session, nice 150 mile run up the California coast with the AFR meter. Mike |
mgphoto |
Nov 13 2017, 03:37 PM
Running on the last 2 gallons of the Chevron, I decided to try the Shell product Nitro+??
5 gallons, I set off on the 5 north and an instant later she is Hyde, pings no power above 3000 rpm oil temps start to rise 200*F. Ambiant temps in Los Angeles 73*F humidity at 20%. I was saving this test for higher temps but here goes. I pull the connector from the Temp Sensor I in the intake plenum. Idle drops, because of the rich condition, I readjust the idle using the air screw. I take her back out on the 210 fwy, JECKELL is BACK, up hill WOT power and no ping, I drive about 20 miles 85 to 90 mph, oil temps never cracked 190*F. So I can see at this point that throwing fuel at the problem has an instant effect. OK so I see and AFR meter secession in my future. |
Lo-Fi Version | Time is now: 6th January 2025 - 10:26 PM |
