L-Jet Auxillary Air Regulator or Valve?, Proper operation of the AAR |
malcolm2 |
Oct 17 2017, 12:38 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I found an very old, very short post about the subject and cleaning the AAR with PB Blaster. So I guess I'll try that. But that post did not answer my current problem.
I have had my AAR off of my car and the hose connections plugged for about 6 months now. But it is getting cold and it has been recommended that I put it back in service. So I tested it. And took some pictures along the way. I did the FREEZER test and it opened. I sat it in the sun. Very warm exterior case. Kinda tuff to hold it. It absorbed a good bit of heat.... and almost closed. Then I broke out my handy dandy 12v drill battery and within a few seconds it was closed. here is the question..... I tried to blow thru the closed hole and had ZERO problem doing that. So I suppose when closed that NO AIR should pass thru, correct? Will the PB Blaster cleaning help, or is this baby done for? Any ideas on fixing? Thanks. |
timothy_nd28 |
Nov 13 2017, 04:45 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
Since your AAV is now functioning correctly, I would warm up the engine and reset the timing and adjust the idle screw.
Lo-Fi Version | Time is now: 27th December 2024 - 10:27 AM |
