bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
My Webers have the cold start circuits installed. While I'm replacing the floor pan and have easy access to the tunnel, I am thinking about adding a couple tubes to run cables from a hand throttle lever to the carbs to operate the chokes. Wondering if anyone has done this and whether it would provide superior cold starting to the traditional hand throttle. I live in the frigid north where it can freeze any day of the year, so I want the best cold start operation I can get. Thoughts?
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
My fuel pump (CB Peformance 3.5psi) comes on as soon as the key is turned. When it's cold I turn on the key, pump the throttle a few times and squirt some fuel in and it starts up great. I don't too often operate in below freezing temps but when I do, I use the same procedure. Works great for me. (IMG:style_emoticons/default/smile.gif) I never felt the need to hook them up.
Lo-Fi Version | Time is now: 26th June 2024 - 12:58 AM |
