76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
I'm going to have several electrical questions. 1st, Is pin #8, on the 14 pin plug at the relay board, the only switched 12v+ source in the engine compartment? TIA, Kent
76-914 |
This is one of those subjects that the more I read about it the less I understand so let me state it as simple as my mind works. (IMG:style_emoticons/default/blink.gif) The '70 V8 conversion I'm completing has a single wire (internal VR) alternator. The relay board isn't being used so should I delete the "blue" wire connection on the 14 pin connector? I'm using a '73 harness if it makes any difference and will be using a volt meter as well. If it is deleted what else will be required? TIA, Kent
Lo-Fi Version | Time is now: 26th June 2024 - 07:09 AM |
