> Show Me Your In Cabin Fire Extinguishers Please!, Stuck! Looking For Some Creative Ideas
Lucky9146
post Nov 20 2017, 11:27 PM
Ok, I got this cool center pull hand break (not my idea) but I sure like it there.
Now with that said, I have some real estate limitations shall we say.
I'd sure appreciate seeing what you guys have done, type, and the size you have selected etc.
Thanks (IMG:style_emoticons/default/bye1.gif)
(IMG:style_emoticons/default/white914.jpg)
oakdalecurtis
post Nov 21 2017, 12:18 AM
Oakdalecurtis
Hi Brian, this is a repost of a product I found recently that you may want to consider:
I purchased the 6 foot BlazeCut Fire Suppression System. This length only requires one length down one side of the lid, one curve, and one length back the other side of the lid. I also found that the stiff tubing does not like to bend into a tight enough arc to fit into the confines of the engine lid. The tube kinked at the center of the curve, but I don't think it damaged it. I bought an electrical gray pipe curve, 3/4" ID, split it with my band saw, and zip tied and taped it around the BlazeCut tubing at the center of the arc where the tubing wanted to kink. This supported and held the tubing, keeping the tubing in the required arc while preventing it from kinking. I also found that plastic zip ties were not strong enough to hold the tubing in position under the engine lid. The stiff BlazeCut tubing does not like to bend or go where you want it to very easily. As you can see, I removed my rain tray a while ago since I never take the car out in bad weather and the engine runs cooler without it.
I fastened the tubing to the underside of the engine lid using metal pipe claps, 3/4 ID, and short self tapping metal screws into the lid supports. I wrapped the BlazeCut in heavy plumbers tape wherever it came in contact with the metal lid. I also cut thin strips of black tape and put them on the top side of the BlazeCut tube so you could not easily see the white tubing through the engine grill from the outside.
If you look on the left side of my engine lid, you can also see a steel braided cable I added a while back so I don't have to hold on to the engine lid when I open it. Without the cable, if you popped the engine lid and didn't hold it, it would fly open and put a lot of bending force on the hinges, which I have already rewelded once. Now the cable catches it before it works on the hinges.
BTW, if you have a weak opening engine cover, here's a link to an easy and simple fix that lets you put more pop in the opening, especially with the extra weight of the BlazeCut under the lid. My lids pops open fully now, even with the tubing under it.
I hope I never have to find out how well the BlazeCut tubing works!
Here's a follow up post you might want to read!
I've owned my '76 teener for about twenty years. I recently installed BlazeCut in the engine compartment to hopefully stop any potential engine fire. I took the car out for a short test ride soon after completing the BlazeCut install. As I was headed back toward home, suddenly thick black smoke started pouring out from under the dash in front of my left leg! I quickly pulled over and shut the car down before a fire started. After the smoke stopped and my heart slowed down, I lowered the relay panel and here's what I saw! After forty years, one of the of the relay bases somehow short circuited internally and melted the surrounding rubber.
I finally got the car home and repaired the melted relay base and all is good now. But I remember what I was thinking when I first saw all that black smoke coming from under the dash. "Great, I have a fire suppression system mounted right behind my back, and the car is going to burn up in front of me in the passenger compartment and there's nothing I can do about it!". I now carry a small fire extinguisher in my custom home made center console box, just in case the fire isn't in the engine compartment!
Lucky9146   Show Me Your In Cabin Fire Extinguishers Please!   Nov 20 2017, 11:27 PM
thelogo   How bout the old put it in the front trunk Mount ...   Nov 20 2017, 11:33 PM
oakdalecurtis   Hi Brian, this is a repost of a product I found re...   Nov 21 2017, 12:18 AM
RickS   That model of Kidde is recalled due to the plastic...   Nov 21 2017, 12:29 AM
oakdalecurtis   That model of Kidde is recalled due to the plasti...   Nov 21 2017, 01:19 AM
RickS   tunnel mount   Nov 21 2017, 12:32 AM
falcor75   I have mine mounted intfront of the passenger seat...   Nov 21 2017, 03:22 AM
rgalla9146   I have mine mounted intfront of the passenger sea...   Nov 21 2017, 07:26 AM
Kansas 914   I had mine mounted with a single bolt in the same ...   Nov 21 2017, 08:43 AM
23e Heure   This is a great thread: thanks to the OP for gett...   Nov 24 2017, 03:32 AM
pvollma   Has anyone had success with this specific mount,...   Nov 24 2017, 08:15 AM
t collins   :agree: I like the fact that it's always easy ...   Nov 21 2017, 08:38 AM
76-914   RE: Show Me Your In Cabin Fire Extinguishers Please!   Nov 21 2017, 09:26 AM
Coondog   Just my opinion from 30 plus years as a career Fir...   Nov 21 2017, 09:27 AM
porschetub   Just my opinion from 30 plus years as a career Fi...   Nov 21 2017, 12:55 PM
Lucky9146   Just my opinion from 30 plus years as a career Fi...   Nov 21 2017, 03:18 PM
aharder   Just my opinion from 30 plus years as a career Fi...   Nov 21 2017, 10:05 AM
pvollma   Found a universal seat mount which worked fine for...   Nov 21 2017, 10:29 AM
porsche913b_sp   Found a universal seat mount which worked fine fo...   Nov 24 2017, 01:36 PM
pvollma   Would you mind sharing where to get this univers...   Nov 24 2017, 03:22 PM
iamchappy   Made bracket for seat, also on board system..   Nov 21 2017, 10:41 AM
Coondog   When most people describe a Fire Ext they refer to...   Nov 21 2017, 12:44 PM
Coondog   Yes, vertical or horizontal doesn’t matter.   Nov 21 2017, 01:23 PM
porschetub   Yes, vertical or horizontal doesn’t matter. T...   Nov 21 2017, 01:57 PM
aharder   I guess I should have asked what capacity of each ...   Nov 21 2017, 02:20 PM
Coondog   My Purple K is a 5 pound 20 BC My Halotron is a 2 ...   Nov 21 2017, 03:42 PM
ThreeV8s   My Purple K is a 5 pound 20 BC My Halotron is a 2...   Nov 23 2017, 10:13 AM
Coondog   My Purple K is a 5 pound 20 BC My Halotron is a ...   Nov 23 2017, 10:52 AM
ThreeV8s   [quote name='ThreeV8s' post='2550973' date='Nov 2...   Apr 5 2018, 06:15 PM
Coondog   [quote name='ThreeV8s' post='2550973' date='Nov ...   Apr 6 2018, 08:54 PM
somd914   Thanks for the clarification on Purple K's non...   Nov 21 2017, 09:22 PM
Biggles   Personally, i didnt want anything directly under m...   Nov 22 2017, 04:43 PM
porschetub   Personally, i didnt want anything directly under ...   Nov 23 2017, 05:51 PM
1970 Neun vierzehn   Halon extinguisher mounted to heavy-duty magnets a...   Nov 22 2017, 06:31 PM
Frank S   Halon extinguisher mounted to heavy-duty magnets ...   Nov 24 2017, 09:14 AM
porsche913b_sp   Halon extinguisher mounted to heavy-duty magnets ...   Nov 24 2017, 01:38 PM
1970 Neun vierzehn   Halon extinguisher mounted to heavy-duty magnets...   Nov 24 2017, 09:19 PM
RickS   [quote name='porsche913b_sp' post='2551334' date=...   Nov 29 2017, 10:26 PM
pete000   Made mine. Pretty easy to do...No drilling   Nov 22 2017, 11:49 PM
Marv's3.6six   Not sure if I posted this before. I wanted the ext...   Nov 24 2017, 11:41 AM
GeorgeRud   I also mounted my Halon extinguisher in front of t...   Nov 24 2017, 05:08 PM
domer914   The location of mine is already represented here, ...   Nov 24 2017, 09:28 PM
Lucky9146   The location of mine is already represented here,...   Nov 29 2017, 11:56 AM
Big Len   I took coondog's advise too and bought a Purpl...   Apr 6 2018, 09:39 AM
Coondog   I took coondog's advise too and bought a Purp...   Apr 6 2018, 08:54 PM
brant   just an observation.. regarding Halon I now hav...   Apr 6 2018, 02:44 PM
ThreeV8s   I took @coondog’s advice (finally) and got a 5...   Apr 7 2018, 02:09 AM
Big Len   Instead of mounting, it fits perfectly behind the ...   Apr 24 2018, 04:56 AM
- Lo-Fi Version Time is now: 20th April 2025 - 12:22 AM
