davesprinkle |
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None ![]() ![]() |
Driving Santa Rosa Creek Road today. I banged a 3-2 downshift. Couple of pops in the exhaust, then no torque. I coast to a stop. Engine cranks fast but doesn't light.
I put a finger on the air flap and hear the fuel pump run. Good. Voltage to the coil? 10.8V. (Low, but I've been cranking on this damn thing for a bit. So, OK.) I pull the distribulator cap and look at the points. OK. I'm out of easy options, so I start walking. Seven miles back to town. No cell service. I'm thinking I bent some valves on an over-rev. Here's a pic: Attached image(s) ![]() |
drifter914 |
drifter914 ![]() ![]() Group: Members Posts: 50 Joined: 12-May 13 From: pearce, arizona 85625 Member No.: 15,863 Region Association: Southwest Region ![]() |
Also... check to see if coil is loose in bracket. If it rotates around, can sometimes ground itself on engine tin. Same result !
Hope it's something simple. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:19 AM |
