davesprinkle |
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None ![]() ![]() |
Driving Santa Rosa Creek Road today. I banged a 3-2 downshift. Couple of pops in the exhaust, then no torque. I coast to a stop. Engine cranks fast but doesn't light.
I put a finger on the air flap and hear the fuel pump run. Good. Voltage to the coil? 10.8V. (Low, but I've been cranking on this damn thing for a bit. So, OK.) I pull the distribulator cap and look at the points. OK. I'm out of easy options, so I start walking. Seven miles back to town. No cell service. I'm thinking I bent some valves on an over-rev. Here's a pic: Attached image(s) ![]() |
'73-914kid |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California ![]() ![]() |
If I remember correctly, there's a NAPA in Cambria, or at least there used to be, as well as a number of hot rod shops all in a small industrial park on the south part of the town.
Does the car sound the same as it usually does when it cranks? If you smacked/bent valves, you would hear one or more cylinders lacking compression when cranking, as the motor speeds up on the compression stroke of the bad cylinder. I would check for spark. I know it happened on a rough downshift, but a couple of pops, then nothing, sounds like a bad ignition coil. I've had a couple of coils fail and cough a similar death.. Man, if only this happened to you a week later.. Ill be up there next weekend.. |
davesprinkle |
Does the car sound the same as it usually does when it cranks? If you smacked/bent valves, you would hear one or more cylinders lacking compression when cranking, as the motor speeds up on the compression stroke of the bad cylinder. The car definitely sounds different during cranking. Spins very fast. I'm thinking I tapped valves in all four. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:43 AM |
