Motor is tight when turning by hand |
swood |
Nov 6 2004, 10:14 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Ok, I've finally cut the p-rods and am loading them in and adjusting the valves. Right now it's on TDC for #1. I notice that when I turn the flywheel, at some point in the rotation there is a little tightness for a few degrees, maybe a 1/4 turn or so. My jugs were opened to 96mm with new KB's and hastings rings. Could this be just the rings on one of the pistons when down low in the cylinder? I don't know how free a new motor is to turn. The crank turned smooth as silk before connecting the rods, p&c's etc.
My hands hurt from the teeth on the flywheel so any thoughts would be great. |
914GT |
Nov 6 2004, 10:40 PM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
Did you notice it before tightening the valves? Did you have the rods off the crank?
(edit) never mind the second question. Did you fit the rods on the crank before installing them in the case, to check your clearances? |
Lo-Fi Version | Time is now: 20th June 2024 - 05:43 AM |
