| North Coast Jim |
Dec 2 2017, 01:38 PM
Member ![]() ![]() Group: Members Posts: 341 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region
Changed out both the Directional switch and the Wiper switch in the 914 a week or so ago. Seems to be working fine EXCEPT - the wiper return to off capability still doesn't work.
I have the following steering wheel, part number 914-347-8041, a hard plastic phenolic ?? wheel with the following return post, see pics. Seems the return post isn't long enough to mate with the switch mechanism. Is it broken off or is there another part I should be looking for ?? I've scoured the World for previous posts on this subject to no avail. Or maybe I'm still a rooking at looking Thanks all ![]() ![]() |
| SirAndy |
Dec 3 2017, 01:23 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,370 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
the wiper return to off capability still doesn't work. Just to clarify, you are actually talking about the blinker cancel, not a wiper cancel? (IMG:style_emoticons/default/idea.gif) |
North Coast Jim Directional switch return to off Dec 2 2017, 01:38 PM
JamesM Buy about 20 turn signal switches from as many dif... Dec 3 2017, 12:31 AM
76-914 PM Mark Heard "914SIXER". He scours the ... Dec 3 2017, 08:25 AM
mzalanka I have dealt with this same issue. It shouldn’t ... Dec 3 2017, 12:32 PM
North Coast Jim
I have dealt with this same issue. It shouldn’t... Dec 3 2017, 01:12 PM
mzalanka Ok good. You’ve ruled out a problem with the swi... Dec 3 2017, 01:27 PM
North Coast Jim
[quote name='North Coast Jim' post='2554193' date... Dec 3 2017, 03:02 PM
North Coast Jim
[quote name='North Coast Jim' post='2554193' date... Dec 3 2017, 04:08 PM
mm911
[quote name='North Coast Jim' post='2554193' date... Jul 12 2025, 11:28 AM
Hans Jan :popcorn: Dec 3 2017, 04:22 PM
Valy Is the canceling tab on the steering wheel mounted... Dec 3 2017, 10:54 PM
Jonathan Livesay
Is the canceling tab on the steering wheel mounte... Dec 4 2017, 10:43 AM
barefoot
Is the canceling tab on the steering wheel mount... Jul 11 2025, 05:23 PM
North Coast Jim Thanks all for the valuable input. Will try these ... Dec 6 2017, 10:30 AM
jim_hoyland PM sent Need to find out how you finally fixed it Apr 25 2025, 07:08 PM
jim_hoyland Is the Dansk TS switch known to not cancel ? Jul 11 2025, 04:44 PM
914sgofast2 I had the same problem when replacing the turn sig... Jul 12 2025, 02:57 PM
jim_hoyland Thanks, good tips :) Were there supposed to be 4 ... Jul 12 2025, 03:34 PM
914sgofast2 No washers under the switch. I was referring to th... Jul 13 2025, 02:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th December 2025 - 05:23 AM |
