Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,680 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
These are those pesky rubber bushings that go inside the top of the strut tower mount. Yes you can buy new metal mounts with the new rubber.....at $180 each!
I designed these to allow for install using a press, or with threaded rod, some washers and nuts. Getting the old one out is the hardest part. You can use a sharp knife to cut the upper lip and knock the rubber out the bottom. As the lip is what's holding it in. You can use a press and it will pop out. Install is pretty easy. I designed it to act like a wedge-lock. Align the rubber in the metal part and use a bench vice (or press) to push the two sides together. I used a lower graphite content poly-graphite to allow these to push together under pressure. It creates a wedge lock that will hold the parts in place . You can see that the depth of engagement is correct on the top when the metal tube hits the ends of the bushing. It will be almost fully engaged but will require tightening about 1/8" more down during the install for the strut. I think you will like these, especially for the price! Also good to install while you do the A -arm rubber (IMG:style_emoticons/default/poke.gif) Attached thumbnail(s) ![]() ![]() ![]() ![]() |
Mikey914 |
Maybe we should add that option. We had never really done much as far as gift certificates but maybe we should ?
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,333 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Maybe we should add that option. We had never really done much as far as gift certificates but maybe we should ? Yes, you should. I used to work retail. Gift certificates are a winner for every type of merchant. No need to scam. Your getting paid now for product you send later. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:37 AM |
