chris914 |
Member ![]() ![]() Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California ![]() |
Hi,
Whats the trick to replacing the rollers for the rear trunk? |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
raise the trunk. use a deep 8, 9,or 10mm(i forget) socket and extension. slip it over the spring end. it will push down easily so you can slip the roller on. if you are going to stay with springs, use the metal rollers. you need the correct fuel line clamps. (IMG:style_emoticons/default/ohmy.gif)
kevin |
Lo-Fi Version | Time is now: 27th June 2024 - 03:32 AM |
