Keep Dellorto DRLA 45s and Bosch 009? |
98101 |
Nov 25 2017, 05:44 AM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
I suddenly find myself owning 1970 4-cylinder 2.4 with Web hot street Cam idles nicely and pulls hard at WOT. Part throttle response is not great, often with carbs coughing and even backfiring on trailing throttle. My use is mostly street, so I'd like to get this part throttle stuff sorted.
Here's pictures of the stuff that's in there now. I guess that's the infamous Bosch 009 with no vacuum advance and a PerTronix 1847A. The carbs are Dellorto DRLA 45s with short velocity stacks and these tall foam things that don't seal against the air cleaner housings. I'm willing to learn about the carbs but I don't have much confidence in the 009 for running nicely on the street. Please correct me if I'm wrong about any of this stuff. Also from other threads I gather that switching to EFI such as MicroSquirt would cost $5K or so ... though I'm not ruling this out completely. Correct me if I'm wrong about that. Is this kind of linkage OK? Here's the idle you may have seen in another post: https://www.youtube.com/watch?v=-AC53RRrXOU Any help you can provide is appreciated! --Michael in Seattle |
MarkV |
Dec 14 2017, 08:54 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
I fought with mine when I first set them up. Make sure that the linkage on both cars are symmetrical. The rods that attach from the linkage to the arm on the carb should be the same angle... otherwise one carb is going to open at a different rate than the other. You can operate the linkage with the car running manually to check the flow at higher rpm. I try to hold it at 2500 rpm and compare one carb to the other to ensure the linkage is working correctly. Set the idle with one side disconnected and then reconnect and make sure that there is no change in rpm when you reconnect... adjust the rod if you have to so that the rpm doesn't change.
I noticed in your photos that there is a spring on your throttle cable. I have never seen that before. My carbs have springs built in to the throttle shaft. That extra spring may be causing your idle to change with engine temperature. I have my cable adjusted so that there is a little bit of slack in it so that as the engine heats up it doesn't pull on the cable and change the idle. You might try eliminating the spring on the cable. |
Lo-Fi Version | Time is now: 25th November 2024 - 09:44 AM |
