Keep Dellorto DRLA 45s and Bosch 009? |
98101 |
Nov 25 2017, 05:44 AM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
I suddenly find myself owning 1970 4-cylinder 2.4 with Web hot street Cam idles nicely and pulls hard at WOT. Part throttle response is not great, often with carbs coughing and even backfiring on trailing throttle. My use is mostly street, so I'd like to get this part throttle stuff sorted.
Here's pictures of the stuff that's in there now. I guess that's the infamous Bosch 009 with no vacuum advance and a PerTronix 1847A. The carbs are Dellorto DRLA 45s with short velocity stacks and these tall foam things that don't seal against the air cleaner housings. I'm willing to learn about the carbs but I don't have much confidence in the 009 for running nicely on the street. Please correct me if I'm wrong about any of this stuff. Also from other threads I gather that switching to EFI such as MicroSquirt would cost $5K or so ... though I'm not ruling this out completely. Correct me if I'm wrong about that. Is this kind of linkage OK? Here's the idle you may have seen in another post: https://www.youtube.com/watch?v=-AC53RRrXOU Any help you can provide is appreciated! --Michael in Seattle |
porschetub |
Dec 17 2017, 02:38 PM
Advanced Member Group: Members Posts: 4,729 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Holy cr#p never seen base caskets like that,WAY too thick if they are overtightened you could bend the carb bases...seen it before ,thick cork gaskets can do the same.
The correct gaskets are only 1mm thick and usually high temp material,I have an Italian Dellorto kit in front of me now. The OP needs to go right through this whole setup and start again from scratch,every problem or potential issue needs to be sorted before trying to tune them afterall. |
Lo-Fi Version | Time is now: 25th November 2024 - 09:53 AM |
