How many turns on a lug not for saftey?, put on 7mm spacer..only get 6 full turns |
jim912928 |
Nov 7 2004, 04:57 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Ok...I've got the silver 914 with the boxster rims. For a short time (so I could drive it some)...I put the 6" wheels in the back and the 7" wheels in the front (I'm running 205 50 16"'s. Backspacing worked great this way. This weekend I went to work on getting the 6" rims in the front and the 7" rims in the back. Rears fit perfect and the fronts, as expected..sit in some. I put some 7mm spacers on the front to pull them out alittle. Now I only get 6 full turns on the lug nuts from first thread catch to full torque down at 97 ft/lbs. Is this too few turns to be safe?
My alternatives are...add longer wheel studs or get two 7" rims to match the rears (7X16" boxster rears with the 40mm offset fit perfect front and rear). I do have a line on 2 7" rims so that isn't a problem. Thoughts? |
Eric_Shea |
Nov 7 2004, 07:19 PM
PMB Performance Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
PCA Rules say 14mm needs to be threaded (they actually say, as mentioned earlier, depth = width of stud, which is 14mm)
I put 7mm spacers on the back of the RS Clone and I restudded. It's funny, it's only about 1/4" but... |
Lo-Fi Version | Time is now: 29th June 2024 - 03:25 AM |
