1adam12 |
Member ![]() ![]() Group: Members Posts: 209 Joined: 25-May 17 From: Chino Hills, CA Member No.: 21,132 Region Association: Southern California ![]() |
I took my injectors out of my '72 1.7l over the weekend and found that the PO used RTV gasket sealant to seal off the #2,#1 fuel injectors (IMG:style_emoticons/default/dry.gif) Upon further inspection, I noticed that the stepped o-ring/grommets where missing. I purchased an injector o-rings set from my local auto store thinking that would be it but nope. Can someone please tell me what that o-ring/grommet is called and where I can purchase them?
It's placed in the bottom opening of the intake runners where the injector is installed. |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Those are not type 4 injector seals. 914 seals do not have a lip.
1adam12 |
Those are not type 4 injector seals. 914 seals do not have a lip. This grommet/seal actually installs in the injector port on the intake runner... well at least on my #3, and #4 injectors. It seemed that it was factory because the injectors fit much more snug and the grommet/seal fit flush in the base of the runner. I rather be 100% sure on this as it's on my set up and the PO used gasket sealant on the injectors that did not have this grommet. |
Lo-Fi Version | Time is now: 26th June 2024 - 03:37 AM |
