Look like the right list of bits for a 914/6 build |
Tdskip |
Jan 11 2018, 11:25 AM
Advanced Member Group: Members Posts: 3,702 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Good morning, can we pretend for a minute that I was going to do a 914/6 build with a 1974 that is already missing its engine. Further, can we imagine that I would be trying to build a car that would be used rather than showed, and that building a clone and/or a "correct" car is not a goal. The goal would be a well balanced, reliable and sorted out car for backroad touring use.
Does this look like the necessary bits? -2.7 or 3.0l engine with CIS (have this) -engine tin -oil tank -front oil cooler -to/from oil cooler lines -throttle linkage -fuel pump -fuel lines -engine lid latch relocation bits (due to CIS) -headers -flywheel -ECU -CDI box -O2 sensor -Engine mount -320i front brakes since the extra horsepower probably deserves it Edit - adding these from Cario and Defianty muffler thermostat for the oil cooler gauges to work with new engine Filler neck for the oil tank Oil dipstick Oil filter console Six muffler 19mm master cylinder FI harness (missed that one) Edit - adding from Lucky9146 Conversion Wiring harness? 914-6 trans mid-plate for throttle or some other contraption, not sure w/FI Shift Rod modified for headers Oil cooler thermostat Oil cooler shroud Oil Cooler Fans Oil Fed chain tensioners Edit - adding from mb911 headers or heat exchangers Am I missing anything? I did try searching and reading prior discussions. Thanks! |
burton73 |
Jan 11 2018, 03:18 PM
burton73 Group: Members Posts: 3,692 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Do you have the car yet?
I seem to remember you getting out of a car before you got into it but lost a deposit? I am old and may have that wrong. I am in Los Angeles So cal. where are you. Good list of stuff for a conversation. Bob B |
Tdskip |
Jan 11 2018, 03:59 PM
Do you have the car yet? I seem to remember you getting out of a car before you got into it but lost a deposit? I am old and may have that wrong. I am in Los Angeles So cal. where are you. Good list of stuff for a conversation. Bob B Hi Bob, you are remembering correctly. I actually bought a good car from a great seller early this week. It is a ‘74 with a solid body, engine gone already, and driver + paint. Came with a running 2.7L CIS, and I have since tracked down a 3.0L CIS that is ready to go in after a service. Given that the car needs an engine anyway, figured now is the time to dig deep and put one of those engines in. Just focusing on the end goal and not getting an interim 4 cylinder in place only to remove it seems ultimately to be a better approach for my specific goals (to be extra clear I am not dogging original engine cars in anyway). I am in Orange County btw... |
Lo-Fi Version | Time is now: 27th December 2024 - 08:54 AM |
