> Look like the right list of bits for a 914/6 build
Tdskip
post Jan 11 2018, 11:25 AM
Good morning, can we pretend for a minute that I was going to do a 914/6 build with a 1974 that is already missing its engine. Further, can we imagine that I would be trying to build a car that would be used rather than showed, and that building a clone and/or a "correct" car is not a goal. The goal would be a well balanced, reliable and sorted out car for backroad touring use.
Does this look like the necessary bits?
-2.7 or 3.0l engine with CIS (have this)
-engine tin
-oil tank
-front oil cooler
-to/from oil cooler lines
-throttle linkage
-fuel pump
-fuel lines
-engine lid latch relocation bits (due to CIS)
-headers
-flywheel
-ECU
-CDI box
-O2 sensor
-Engine mount
-320i front brakes since the extra horsepower probably deserves it
Edit - adding these from Cario and Defianty
muffler
thermostat for the oil cooler
gauges to work with new engine
Filler neck for the oil tank
Oil dipstick
Oil filter console
Six muffler
19mm master cylinder
FI harness (missed that one)
Edit - adding from Lucky9146
Conversion Wiring harness?
914-6 trans mid-plate for throttle or some other contraption, not sure w/FI
Shift Rod modified for headers
Oil cooler thermostat
Oil cooler shroud
Oil Cooler Fans
Oil Fed chain tensioners
Edit - adding from mb911
headers or heat exchangers
Am I missing anything? I did try searching and reading prior discussions.
Thanks!
Mark Henry
post Jan 12 2018, 06:05 PM
that's what I do!
You also need a 914 oil cooler or a 911 cooler modified to 914 spec. I would recommend you keep the factory cooler and since you're in a hot area the front cooler.
Ben's (mb911) oil tank is about the best deal going, I believe he can set you up with just about everything needed in that area. Ben is also reproducing the front cooler lines.
The adaptor clutch from KEP I mentioned will work on both the 2.7 and 3.0/3.2, just the flywheels are different.
The BMW brakes are old school, it's debatable if it gives much more stopping power.
Most do the 5 lug porsche conversion, I did the 3" struts with Alfa brembos which are the same as 914/early 911 M calipers but in alunimum.
You would need 5 bolt rims, but those 4 bolt fuchs you have are in demand to offset cost.
Really take your time and look at other peoples conversion threads before you plop down cash. The /6 conversions are getting spendy and you don't want to be buying wrong bits.
Tdskip
post Jan 12 2018, 10:01 PM
QUOTE(Mark Henry @ Jan 12 2018, 06:05 PM) *
Thanks Mark
Tdskip   Look like the right list of bits for a 914/6 build   Jan 11 2018, 11:25 AM
Cairo94507   That's a pretty good start. You might want to...   Jan 11 2018, 11:31 AM
defianty   Yep that's a good list to start, here's a ...   Jan 11 2018, 11:36 AM
Tdskip   Thanks gentlemen. @Cario, thanks for pointing out...   Jan 11 2018, 11:48 AM
tomeric914   Take a look at my build thread for some ideas. Mi...   Jan 11 2018, 11:51 AM
Tdskip   Take a look at my build thread for some ideas. M...   Jan 11 2018, 11:51 AM
mepstein   Horsepower has nothing to do with needing bigger b...   Jan 11 2018, 12:17 PM
Tdskip   Horsepower has nothing to do with needing bigger ...   Jan 11 2018, 03:53 PM
Lucky9146   Yes good start. Probably need: Conversion Wiring...   Jan 11 2018, 12:19 PM
Tdskip   Yes good start. Probably need: Conversion Wirin...   Jan 11 2018, 04:02 PM
burton73   Do you have the car yet? I seem to remember you g...   Jan 11 2018, 03:18 PM
Tdskip   Do you have the car yet? I seem to remember you ...   Jan 11 2018, 03:59 PM
Tdskip   Here she is...   Jan 11 2018, 04:03 PM
mb911   Great list also 6 headers or heatexchangers will b...   Jan 11 2018, 04:21 PM
Tdskip   Great list also 6 headers or heatexchangers will ...   Jan 11 2018, 05:17 PM
barefoot   If you're sticking with the CIS and want O2 se...   Jan 11 2018, 04:48 PM
Tdskip   If you're sticking with the CIS and want O2 s...   Jan 11 2018, 05:19 PM
burton73   You are on your way. Great guys that will help you...   Jan 11 2018, 05:25 PM
Tdskip   You are on your way. Great guys that will help yo...   Jan 11 2018, 05:30 PM
mepstein   CIS, in Good working condition, makes for a nice d...   Jan 11 2018, 06:18 PM
Tdskip   CIS, in Good working condition, makes for a nice ...   Jan 11 2018, 06:48 PM
mb911   How about patience and overage money and more pati...   Jan 11 2018, 06:19 PM
Tdskip   How about patience and overage money and more pat...   Jan 11 2018, 06:49 PM
burton73   How about patience and overage money and more pa...   Jan 11 2018, 10:31 PM
Larmo63   Money, and patience. I almost gave up on my conve...   Jan 12 2018, 12:13 AM
Tdskip   Money, and patience. I almost gave up on my conv...   Jan 12 2018, 08:40 AM
mepstein   Money, and patience. I almost gave up on my con...   Jan 12 2018, 08:48 AM
GeorgeRud   Though you have warm weather in California, you st...   Jan 12 2018, 09:02 AM
Mark Henry   I'd vote 3.0 as well, it's what I have, bu...   Jan 12 2018, 09:04 AM
Tdskip   I'd vote 3.0 as well, it's what I have, b...   Jan 12 2018, 01:55 PM
Mark Henry   You also need a 914 oil cooler or a 911 cooler mod...   Jan 12 2018, 06:05 PM
Tdskip   You also need a 914 oil cooler or a 911 cooler mo...   Jan 12 2018, 10:01 PM
Tdskip   OK - to try and get myself organized and start hun...   Jan 12 2018, 10:14 PM
porschetub   OK - to try and get myself organized and start hu...   Jan 13 2018, 12:23 AM
Blue6   Great list also 6 headers or heatexchangers will...   Jan 12 2018, 10:42 PM
Tdskip   If you skip the heat exchangers, just add seat he...   Jan 12 2018, 10:54 PM
raynekat   Perry Kiehl (on this website) will build you a kil...   Jan 12 2018, 11:51 PM
Tdskip   Wait - Forrest is on here? Great. I know him, I w...   Jan 13 2018, 06:58 AM
mepstein   914-6 trans mid-plate for throttle or some other c...   Jan 13 2018, 07:15 AM
Tdskip   914-6 trans mid-plate for throttle or some other ...   Jan 13 2018, 07:56 AM
mb911   Tom, I am going to try to call you today to talk ...   Jan 13 2018, 08:44 AM
Tdskip   Tom, I am going to try to call you today to talk...   Jan 13 2018, 08:45 AM
Tdskip   Good morning. Quick follow-on question; I sourced...   Jan 19 2018, 06:52 AM
mb911   Did you decide to run a 3.0? I would don't rec...   Jan 19 2018, 06:03 PM
Tdskip   Did you decide to run a 3.0? I would don't re...   Jan 19 2018, 06:10 PM
Tdskip   OK - time for an update here. I've decided to...   Mar 8 2018, 05:09 PM
mepstein   OK - time for an update here. I've decided t...   Mar 8 2018, 05:53 PM
Tdskip   OK - time for an update here. I've decided ...   Mar 8 2018, 06:42 PM
mb911   [quote name='mepstein' post='2587087' date='Mar 8...   Mar 9 2018, 06:11 AM
mb911   You will now for sure want 1.625 heat exchangers.....   Mar 8 2018, 06:24 PM
mepstein   You don’t need a custom engine harnes with a 3.2...   Mar 8 2018, 07:05 PM
Tdskip   You don’t need a custom engine harnes with a 3....   Mar 9 2018, 10:13 AM
Tdskip   Good morning. I have made pretty good progress on...   Apr 9 2018, 07:49 AM
Cairo94507   Outstanding progress on getting all of your parts ...   Apr 9 2018, 08:40 AM
Tdskip   Outstanding progress on getting all of your parts...   Apr 9 2018, 09:03 AM
mb911   Let me know what you decided on headers or heatexc...   Apr 9 2018, 12:04 PM
GeorgeRud   Ben should have oil cooler lines and ducting for y...   Apr 9 2018, 02:48 PM
Larmo63   Did this build go over the cliff? What happened h...   May 30 2019, 09:08 PM
Tdskip   Did this build go over the cliff? What happened ...   Jul 12 2019, 07:06 AM
Tdskip   RE: Look like the right list of bits for a 914/6 build   Jul 12 2019, 07:09 AM
Tdskip   Oh, and I had my 2002Tii engine rebuild. And boug...   Jul 12 2019, 07:13 AM
Jonathan Livesay   Oh, and I had my 2002Tii engine rebuild. And bou...   Jun 11 2020, 01:48 PM
Tdskip   Dusting this off as I don't believe I asked ab...   Jun 11 2020, 01:26 PM
mepstein   Yes. I would have the one with the engine checked ...   Jun 11 2020, 01:33 PM
Tdskip   Yes. I would have the one with the engine checked...   Jun 11 2020, 01:42 PM
mepstein   Yes. I would have the one with the engine checke...   Jun 11 2020, 02:25 PM
Tdskip   Been a while but getting serious about getting the...   Sep 16 2020, 07:50 PM
porschetub   Good to see you are getting on with it :D ,someon...   Sep 17 2020, 05:14 PM
Tdskip   Thanks mate, appreciate the response. I’ve seen...   Sep 17 2020, 05:20 PM
Mark Henry   Dan Roots template that I used, set printer at 8.5...   Sep 18 2020, 08:18 AM
Mark Henry   dp   Sep 18 2020, 08:34 AM
Tdskip   Thank you Mark!   Sep 18 2020, 08:43 AM
Tdskip   Got some good news today, the shop going through t...   Sep 25 2020, 06:18 PM
nditiz1   Thats great news. Sell the Naro and get the OEM s...   Sep 25 2020, 07:09 PM
Tdskip   It’s in.   Oct 24 2020, 02:31 PM
28 User(s) are reading this topic (28 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 09:36 AM
