Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
Good morning. The 901 on my project has already been removed from the car. I need to open it up to replace the 2nd gear synchro and it obviously needs to be clear clean clean before I do that.
Is it safe to pressure wash the exterior case so long as I don’t spray where the input shaft is? And been there / cleaned that tips to share? Thanks! |
sdoolin |
Member ![]() ![]() Group: Members Posts: 367 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None ![]() |
If you are careful around the seals, and tape the breather well, pressure washer will work. I did this a little over a year ago (pressure washer), with no ill effect. I was VERY careful.
Lo-Fi Version | Time is now: 26th June 2024 - 10:19 AM |
