mattillac |
robots! ![]() ![]() ![]() Group: Members Posts: 536 Joined: 27-October 04 From: vallejo,ca Member No.: 3,020 ![]() |
i was considering aftermarket pefi and a turbo for my
type-4 914, but plumbing the turbo without cutting out the trunk or using really long tubing seems difficult. anyone have a 914 with a turbo? any pictures? (IMG:style_emoticons/default/monkeydance.gif) |
airsix |
I have bees in my epiglotis ![]() ![]() ![]() ![]() Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 ![]() |
QUOTE(Mueller @ Nov 8 2004, 03:02 PM) ....of all of the turbo's I've seen in 914s, the turbo is place either way in the back near the muffler with the intake tube being real long, or with the turbo mounted in the engine compartment with the exhaust tube being real long.... Mine is actually somewhere inbetween. My turbo is 1/2 in the engine compartment and 1/2 out. I don't have any decent pictures, but I'll try to draw you a visual image. The turbo is located on the passenger side almost exactly opposite the starter. The rear vertical engine cooling tin piece has been cut and the compressor (cold) side of the turbo peeks into the engine compartment through the hole cut in the tin. The turbine (hot) side of the turbo is outside the engine compartment along side the bellhousing at about the 2:00 possition. The exit side of the compressor points straight back running paralel to the bottom of the trunk with about 2 inches clearance. Oil drainback is gravity feed into the right valve-cover. I used an IHI turbo from a 1.8 Subaru. It seems to be sized well. Boost starts at 2,300rpm and is still pulling when my injectors saturate at around 5,700rpm @12psi. (I'm working on getting some bigger injectors). Not including the PEFI, adding the turbo only cost $175 for everything. Turbo & all the plumbing: $175 PEFI on the cheap: $500 Pulling away from a late model Impala: Priceless. Pulling away again when he comes back for more: Priceless^2. (IMG:style_emoticons/default/happy11.gif) -Ben M. |
Lo-Fi Version | Time is now: 28th June 2024 - 05:09 AM |
