turn signals stopped working, just the indicators |
malcolm2 |
Jan 25 2018, 08:10 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
This happened to me before. I wish I could remember what I (or we) did to fix it. I did a search for my posts and it did not jump out at me. So if anyone remembers, or has recently repaired this, speak up....
OK here is the deal. I activate the turn signal lever and sometimes the dash indicator will blink twice. Most times not. I don't hear a CLICK when they do work. The Hazards do the same thing. The fuse is fine. The parking feature works fine on either side. Does everyone know that when the key is off and out, if you activate the signal lever, the lights come on on that side? Let know... |
malcolm2 |
Jan 26 2018, 07:07 AM
One additional problem that I did not see yesterday, but once I noticed it this morning, the previous problem started to come back to mind.
the parking brake..... it is not blinking or lighting either. You can see that it is in the circuit above too. I believe I pulled the flasher relay last time and cleaned the spades. Once I re-installed it, everything worked. So it was a connection problem. Now I believe it is more. I will pull that relay today. Thanks, more to come. |
Spoke |
Jan 26 2018, 03:23 PM
Jerry Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
One additional problem that I did not see yesterday, but once I noticed it this morning, the previous problem started to come back to mind. the parking brake..... it is not blinking or lighting either. The 914 OEM flasher was designed to flash even with minuscule load current like the parking brake light. The Wehrle flasher may not flash with such a light load. The EP26 flasher is LED-compatible and flashes at a very low current, like 4ma. Although the EP26 doesn't have the 2nd relay and if the ebrake is pulled, the tach turnsignal indicator will flash. This is true only for the later single turnsignal indicator configuration ('74-'76 cars). |
Lo-Fi Version | Time is now: 26th June 2024 - 06:01 AM |
