Need advice/recommendation CHT/AFM Gauges |
hermich |
Jan 25 2018, 06:14 PM
Newbie Group: Members Posts: 18 Joined: 22-March 10 From: Johns Island, SC Member No.: 11,492 Region Association: South East States |
I am in the process of building a second 914/4 and need advice on what folks are using for cylinder head temp and wide band air/fuel gauges? I am currently using a VDO CHT gauge and an AEM air/fuel gauge on my current car. While looking for gauges for the new build, it appears that the VDO gauge is no longer available and I'm just not sure about the AEM. Any thoughts, suggestions or recommendations of reliable gauges would be greatly appreciated. Thanks in advance.
Herman |
GregAmy |
Jan 26 2018, 10:06 AM
Advanced Member Group: Members Posts: 2,399 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
How about a recommendation for just a sensor that does variable voltage output? Or a resistive circuit sensor with appropriate voltage divider and putput volts/temperature? I'd like to install a CHT input to my DL-1 data acq system, which can be displayed on the DASH1 and warnings set.
Alternatively, how about an existing CHT gauges that has voltage output for data acq? That's what I do for the AEM AFR gauge, it offers voltage output (and I just hide the AFR gauge behind the panel; I only want to see numbers when things go pear-shaped...) |
Montreal914 |
Jan 26 2018, 10:21 PM
Senior Member Group: Members Posts: 1,703 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
How about a recommendation for just a sensor that does variable voltage output? Or a resistive circuit sensor with appropriate voltage divider and putput volts/temperature? I'd like to install a CHT input to my DL-1 data acq system, which can be displayed on the DASH1 and warnings set. Alternatively, how about an existing CHT gauges that has voltage output for data acq? That's what I do for the AEM AFR gauge, it offers voltage output (and I just hide the AFR gauge behind the panel; I only want to see numbers when things go pear-shaped...) Yes, 0-5V output, and reasonably priced too. (post #5) (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 27th November 2024 - 03:36 AM |
