> Fuchs wheel opinions needed, which sizes and widths?, List your Fuchs size choices and reasons!
Which 'fuchs' wheels would you go with on a GT flared tribute?
Choose below: Fuchs front, rear widths and diameters
Fuchs 7" front and 7" rear x 15" dia. (similar to 916) [ 5 ] ** [6.85%]
Fuchs 7" front and 8" rear x 15" dia. (similar to Eric Shea's period correct GT tribute) [ 19 ] ** [26.03%]
Fuchs 7" front and 9" rear x 15" dia. [ 2 ] ** [2.74%]
Fuchs 8" front and 8" rear x 15" dia. [ 4 ] ** [5.48%]
Fuchs 8" front and 9" rear x 15" dia. [ 3 ] ** [4.11%]
Fuchs 7" front and 7" rear x 16" dia. [ 7 ] ** [9.59%]
Fuchs 7" front and 8" rear x 16" dia. [ 18 ] ** [24.66%]
Fuchs 7" front and 9" rear x 16" dia. [ 4 ] ** [5.48%]
Fuchs 8" front and 8" rear x 16" dia. [ 2 ] ** [2.74%]
Fuchs 8" front and 9" rear x 16" dia. [ 9 ] ** [12.33%]
Total Votes: 73
Guests cannot vote
gothspeed
post Jan 16 2018, 07:34 PM
I think I have covered the most common Fuchs wheel size combos for a GT tribute or clone. This would be for aggressive street and possibly light track use. Pick a wheel size combo that you think looks best in your opinion. Then list your reasons ... (IMG:style_emoticons/default/beerchug.gif)
BTW I am certain most have seen this article on Eric Shea's GT:
http://www.retromodmag.com/features/porsche-914-6-gt
Edit: please post pics to further illustrate your preference! (IMG:style_emoticons/default/smile.gif)
gothspeed
post Jan 24 2018, 11:41 PM
^^^ awesome!!! so those are 8s & 9s x 15 in the pic above? any spacers used?
campbellcj
post Jan 27 2018, 08:03 AM
I can't Re Member
QUOTE(gothspeed @ Jan 24 2018, 10:41 PM) *
^^^ awesome!!! so those are 8s & 9s x 15 in the pic above? any spcers used?
Hi & Thanks - Yes they are 15x9 Braid (BZ) wheels for rear, which are race-quality Fuchs look-alikes ($700-900/ea) and factory 15x8 Fuchs up front. I was fortunate to get a great deal on (4) NOS 15x8's a few years ago and now I also have (4) fresh Al Reed refinshed 8's also. Planning to get one more pair of 9's to have a street/garage set and 2 race sets for tire-management purposes.
I tried factory 15x9's but they would not clear the bodywork. IIRC the factory 9 offset is -3mm and the Braid is available in any custom sizing but I went with a 'standard' Porsche offset of 15 for future flexibility to maybe use on a different car or re-sell.
I do use spacers both front and rear but don't have the sizes handy. The front suspension is heavily customized as are the flares (Tangerine not GT) so it's not a typical 914-6 setup. The front has raised and decambered spindles with Carrera A-calipers and thick vented rotors, and fairly large spacers widen the track significantly and are needed for the 15's to clear the brakes & ball joints. SRP swaybar and brake ducting, 22mm hollow t-bars and custom-valved Bilsteins. Also have extra long studs and open steel lug nuts as required. Very effective and strong but heavy setup.
gothspeed   Fuchs wheel opinions needed, which sizes and widths?   Jan 16 2018, 07:34 PM
GeorgeRud   They hold enough rubber and look period correct. ...   Jan 16 2018, 08:05 PM
Edward Blume   These cars don't always measure the same in al...   Jan 16 2018, 08:07 PM
sixnotfour   These cars don't always measure the same in a...   Jan 19 2018, 05:24 PM
Mueller   Research what rubber is available before you pull ...   Jan 16 2018, 09:47 PM
Justinp71   15's (7/8) look the best! Also I think ha...   Jan 16 2018, 11:16 PM
larryM   Factory specs - for those intent on duplicating or...   Jan 17 2018, 12:48 PM
gothspeed   Here is an interesting set of 7's and 8's ...   Jan 19 2018, 04:23 PM
mepstein   The big difference between the wheels is the 8x16 ...   Jan 19 2018, 04:59 PM
Racer   It all depends on tire availability.. which could ...   Jan 19 2018, 05:12 PM
mepstein   It all depends on tire availability.. which could...   Jan 19 2018, 05:36 PM
campbellcj   It all depends on tire availability.. which coul...   Jan 22 2018, 11:32 PM
gothspeed   It all depends on tire availability.. which could...   Feb 16 2018, 03:54 PM
sixnotfour   what no 10.5 & 12 x 17 ??? :beer2: 315/35 dot...   Jan 19 2018, 05:34 PM
ConeDodger   So far I’m the only 7X16 front 9X16 rear. My rea...   Jan 19 2018, 05:35 PM
Spoke   So far I’m the only 7X16 front 9X16 rear. My re...   Jan 19 2018, 05:59 PM
ConeDodger   So far I’m the only 7X16 front 9X16 rear. My r...   Jan 20 2018, 04:19 PM
gothspeed   what no 10.5 & 12 x 17 ??? :beer2: 315/35 do...   Jan 22 2018, 09:04 PM
jmitro   Tires look great :)! What size tires did you...   Jan 23 2018, 08:00 PM
gothspeed   Wow, I forgot about the Weidman option. They have ...   Jan 20 2018, 02:45 PM
mepstein   Wow, I forgot about the Weidman option. They have...   Jan 20 2018, 02:59 PM
ConeDodger   Wow, I forgot about the Weidman option. They have...   Jan 23 2018, 12:02 AM
gothspeed   Wow, I forgot about the Weidman option. They hav...   Jan 23 2018, 10:11 AM
gothspeed   Just thought I'd post some pics of the # 2 opt...   Jan 22 2018, 01:55 PM
mepstein   Even better in person.   Jan 22 2018, 02:10 PM
johnhora   Eric Shea...if you're watchng... What tires s...   Jan 23 2018, 09:23 AM
ConeDodger   Sorry, I didn’t see the questions until now. ...   Jan 23 2018, 08:40 PM
gothspeed   More pics :stir:   Jan 24 2018, 05:26 PM
campbellcj   I've been hearing for years that 16x6's --...   Jan 24 2018, 11:24 PM
gothspeed   ^^^ awesome!!! so those are 8s ...   Jan 24 2018, 11:41 PM
campbellcj   ^^^ awesome!!! so those are 8s ...   Jan 27 2018, 08:03 AM
Mercurial   Hi guys, I'll be running 8 & 9" x 16...   Jan 25 2018, 11:22 AM
gothspeed   Hi guys, I'll be running 8 & 9" x 1...   Jan 25 2018, 03:24 PM
mepstein   I was able to find 205x55x15 and 225x50x15 in matc...   Jan 25 2018, 03:55 PM
gothspeed   I was able to find 205x55x15 and 225x50x15 in mat...   Jan 25 2018, 04:23 PM
johnhora   Race/track tires in 15" are still available i...   Jan 25 2018, 07:23 PM
mepstein   Race/track tires in 15" are still available ...   Jan 25 2018, 07:51 PM
porschetub   Wow love some of the big rims and tyres shown,its ...   Jan 25 2018, 08:08 PM
johnhora   Race/track tires in 15" are still available...   Jan 25 2018, 09:09 PM
Mercurial   Hi guys, I'll be running 8 & 9" x ...   Jan 25 2018, 09:46 PM
gothspeed   [quote name='gothspeed' post='2571757' date='Jan ...   Feb 7 2018, 06:03 PM
burton73   So this is a picture of #41 when it was just out o...   Jan 25 2018, 11:10 PM
gothspeed   So this is a picture of #41 when it was just out ...   Jan 25 2018, 11:14 PM
gothspeed   ^^^ Cool! Thank you for the info :) Here are ...   Jan 31 2018, 02:18 PM
Justinp71   For reference these are 15x7, 15x8 with 205 50 and...   Jan 31 2018, 02:51 PM
gothspeed   For reference these are 15x7, 15x8 with 205 50 an...   Jan 31 2018, 07:04 PM
ConeDodger   For reference these are 15x7, 15x8 with 205 50 a...   Jan 31 2018, 07:16 PM
Justinp71   For reference these are 15x7, 15x8 with 205 50 a...   Jan 31 2018, 11:14 PM
johnhora   Justinp71 Very nice looking 914... great red...w...   Jan 31 2018, 03:36 PM
Justinp71   Justinp71 Very nice looking 914... great red......   Jan 31 2018, 04:18 PM
Justinp71   Tire sizing chart for the Rival, its also DOT rate...   Jan 31 2018, 11:19 PM
MoveQik   16x7 front and 16x8 rear. LOVE the look but you h...   Jan 31 2018, 11:36 PM
Olympic 914   Another 7x16 Front, 8x16 Rears. 951 wheels 23.3 ...   Feb 1 2018, 08:28 AM
gothspeed   ^^^ Fantastic semi-narrow bodies with 951 7s and 8...   Feb 1 2018, 07:00 PM
sixnotfour   same blue 914 steel 'top with 7$8 x 16 3 ...   Feb 2 2018, 02:57 AM
gothspeed   More pics! B:)   Feb 6 2018, 06:00 PM
mepstein   More pics! B:) That car looks fantastic...   Feb 6 2018, 06:15 PM
VegasRacer   According to the pole, Elvira is the only one runn...   Feb 6 2018, 08:32 PM
Justinp71   According to the pole, Elvira is the only one run...   Feb 7 2018, 12:33 AM
sixnotfour   According to the pole, Elvira is the only one ru...   Feb 7 2018, 02:02 AM
gothspeed   even more pics! :)   Feb 6 2018, 09:48 PM
mepstein   even more pics! :) Glenn Stazak told me thi...   Feb 7 2018, 03:35 PM
johnhora   Everyone... Please be sure to post both the wheel ...   Feb 7 2018, 09:12 AM
gothspeed   Everyone... Please be sure to post both the wheel...   Feb 7 2018, 02:26 PM
johnhora   even more pics! :) Glenn Stazak told me th...   Feb 7 2018, 05:27 PM
Justinp71   I think Adriatic Blue is a really nice GT color, I...   Feb 7 2018, 06:18 PM
mepstein   I think Adriatic Blue is a really nice GT color, ...   Feb 7 2018, 06:29 PM
gothspeed   I've been hearing for years that 16x6's -...   Feb 7 2018, 06:49 PM
johnhora   gothspeed... Yep I tried to zoom in too and it...   Feb 7 2018, 09:25 PM
mepstein   gothspeed... Yep I tried to zoom in too and it...   Feb 8 2018, 06:44 AM
gothspeed   The orange car has nice looking wheel/tire choices...   Feb 8 2018, 02:18 PM
mepstein   Orange one is chris's/campbellcj car   Feb 8 2018, 02:37 PM
campbellcj   Orange one is chris's/campbellcj car Hi al...   Feb 8 2018, 09:58 PM
gothspeed   [quote name='mepstein' post='2576623' date='Feb 8...   Feb 9 2018, 10:08 AM
campbellcj   Thanks for posting tire sizes. I looked those up...   Feb 9 2018, 11:32 AM
gothspeed   [quote name='gothspeed' post='2576930' date='Feb ...   Feb 12 2018, 12:12 PM
johnhora   [quote name='johnhora' post='2576343' date='Feb 7...   Feb 8 2018, 03:15 PM
mepstein   [quote name='johnhora' post='2576343' date='Feb ...   Feb 8 2018, 03:49 PM
gothspeed   [quote name='johnhora' post='2576648' date='Feb 8...   Feb 8 2018, 05:32 PM
burton73   I need tires for my 6--- 7s and 8s 15s Fuchs. Yea...   Feb 8 2018, 03:53 PM
johnhora   :agree: $400+ is pricey for one tire...but ...   Feb 8 2018, 05:03 PM
gothspeed   7-8x16s   Feb 9 2018, 10:39 AM
mepstein   Since Chris's rear wheels are Braids, they cou...   Feb 12 2018, 12:36 PM
gothspeed   Since Chris's rear wheels are Braids, they co...   Feb 12 2018, 12:53 PM
gothspeed   As a few people have mentioned there are few optio...   Feb 13 2018, 10:33 AM
gothspeed   More! B:)   Feb 14 2018, 09:25 AM
mepstein   More! B:) Video game?   Feb 14 2018, 09:53 AM
gothspeed   [quote name='gothspeed' post='2578946' date='Feb ...   Feb 14 2018, 10:55 AM
mepstein   [quote name='gothspeed' post='2578946' date='Feb...   Feb 14 2018, 11:36 AM
gothspeed   [quote name='gothspeed' post='2578983' date='Feb ...   Feb 14 2018, 06:20 PM
gothspeed   This thread needs another pic! B:)   Feb 15 2018, 10:25 AM
campbellcj   My car’s rears are the same Braid / BZ 15x9. Cou...   Feb 15 2018, 11:42 PM
gothspeed   My car’s rears are the same Braid / BZ 15x9. Co...   Feb 16 2018, 09:37 AM
campbellcj   On your 673 car pic above it appears to have the...   Feb 17 2018, 09:43 AM
mepstein   The nice thing about Fuchs are unless you spend a ...   Feb 17 2018, 09:55 AM
restore2seater   So the majority of combinations are 7 front and 8 ...   Feb 17 2018, 10:40 AM
johnhora   Pat... Short answer... You're correct ...in a...   Feb 17 2018, 11:59 AM
restore2seater   Short answer... You're correct ...in a street...   Feb 17 2018, 05:03 PM
sixnotfour   some pics, 15x8 RSR weidman, I added a single piec...   Feb 17 2018, 03:59 PM
johnhora   Pat... Yes turn in is nice... But for me the pro...   Feb 17 2018, 06:47 PM
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 12th April 2025 - 02:31 AM
