> Ex BUILD-OFF CHALLENGE: Brett's 914, Got engine installed and working on wiring!
brettrarnold
post Oct 1 2015, 12:24 AM
New 914 owner in Lakewood CO
Background
This car was the first car that Brett drove when he was 13 and was given to us in 2014. It had been sitting idle back in Indiana under a family friend's carport for the past 15 years before Brett went back to Indiana and towed it out to Colorado with his father in July 2014. (IMG:style_emoticons/default/piratenanner.gif)
When we got it, we didn't have a garage to work on it and it sat idle being stored outside for another year until we could afford a house with a garage. Colorado is pretty expensive so after we got a house with a garage, we then needed to save up more money to work on it.
Also I must mention in my ignorance, there were 3 distinct phases of thinking for getting this car fixed which I now find funny and are listed below
Phase 1: I will tow this car out to Colorado and get it the engine running for maybe $2,000 and have a working car.
Phase 2: Holy shit after researching this is impossible and will have to pay somebody to fix it for $15-20k.
Phase 3: I have enough local support and 914world resources and can fix this myself for around $10-15k.
Build-Off Challenge
So Amy and I are going to be tackling different aspects of this car so the posts will be coming from both of us. I will handling the rust/engine work and Amy will be on Interior and Exterior. Also she may help with some of the posting so we will start each post with name.
Brett
Step 1 (Complete) was to remove the engine and assess the frame rust situation. Never having removed an engine from a car, this was an extremely daunting task. The steps listed in Pelican Parts tutorial - 914 Engine Removal Made Easy is by far the most difficult thing I have done to a vehicle thus far. Hell I don't even know the difference between a camshaft and a carburetor much less a CV joint or a clutch cable. But after staring at it for about 2 weeks, I decided to just start unhooking shit and labeling. Made a ton of progress and finally got the engine about 95% unhooked. Had a friend come over to help me out and we actually got it out. WOOHOO!!!
Step 2 (Complete) is to strip out all the interior. I ordered chassis braces and other misc items from Tangerine racing and am still in the process of identifying all the rust areas that need repair.
rnellums
post Jan 28 2018, 09:18 PM
Professional Enthusiast
Stick with the hydraulic clutch. After looking back at your photos some more looks like you have almost everything you need. Now you just need someone to.come with it for you (IMG:style_emoticons/default/wink.gif)
You'll still need the flywheel and clutch that mates with the transmission.
brettrarnold
post Jan 28 2018, 11:11 PM
Junkyard find or should i buy something newer? Working at the junkyard was quite a good time. There were a bunch of subarus to scavange.
-Brett
QUOTE(rnellums @ Jan 28 2018, 08:18 PM) *
brettrarnold   Ex BUILD-OFF CHALLENGE: Brett's 914   Oct 1 2015, 12:24 AM
Cairo94507   :wttc: Welcome to you and Amy. Looks like a nice ...   Oct 1 2015, 06:52 AM
brettrarnold   :wttc: Welcome to you and Amy. Looks like a nice...   Oct 2 2015, 11:13 AM
rnellums   Just wait till they start posting pictures of that...   Oct 1 2015, 07:11 AM
brettrarnold   Just wait till they start posting pictures of tha...   Oct 2 2015, 11:16 AM
DirtyCossack   The car looks solid at the moment but after talk...   Oct 2 2015, 04:55 PM
RobW   :agree: :wttc: :wttc: If the motor pull was i...   Oct 1 2015, 08:27 AM
mbseto   Man that's is one accusing look from your dog....   Oct 2 2015, 07:25 AM
Mueller   Nice looking car and seems like pretty solid found...   Oct 2 2015, 11:08 AM
turk22   Yea, my first thought in looking at those pictures...   Oct 2 2015, 11:55 AM
Nutter965   Good luck guys, I hope the rust isn't to bad ....   Oct 2 2015, 01:29 PM
PlantMan   That dog is killing me!!!!! Lo...   Oct 2 2015, 01:49 PM
914forme   :wttc: Good luck, the rust is everyones biggest co...   Oct 2 2015, 02:05 PM
Stacks914   Goodluck! love that paint on the car!   Oct 2 2015, 02:08 PM
brettrarnold   Rust Update. While im waiting for chassis braces ...   Oct 4 2015, 02:41 PM
JamesM   For someone that has never pulled an engine that l...   Oct 19 2015, 05:06 PM
brettrarnold   For someone that has never pulled an engine that ...   Oct 20 2015, 07:27 AM
mepstein   Once you start removing paint, floor tar and under...   Oct 4 2015, 03:21 PM
brettrarnold   Once you start removing paint, floor tar and unde...   Oct 4 2015, 04:02 PM
stevegm   After you cut out all of the rust, make sure you t...   Oct 4 2015, 04:18 PM
brettrarnold   Howdy folks, So have kind of been in somewhat of...   Oct 19 2015, 08:49 AM
RobW   1) You can turn the rotors but you can also buy th...   Oct 19 2015, 11:41 AM
brettrarnold   1) You can turn the rotors but you can also buy t...   Oct 19 2015, 11:47 AM
injunmort   did your e-brake function before dismantling? mos...   Oct 19 2015, 04:43 PM
brettrarnold   did your e-brake function before dismantling? mo...   Oct 20 2015, 07:20 AM
76-914   Unless you plan to AX the stock brakes are fine. I...   Oct 20 2015, 09:27 AM
rnellums   Unless you plan to AX the stock brakes are fine. ...   Oct 20 2015, 11:48 AM
brettrarnold   Unless you plan to AX the stock brakes are fine....   Oct 20 2015, 12:39 PM
brettrarnold   Unless you plan to AX the stock brakes are fine. ...   Sep 24 2023, 09:12 PM
mepstein   Unless you plan to AX the stock brakes are fine....   Sep 24 2023, 10:22 PM
brettrarnold   [quote name='brettrarnold' post='3103735' date='S...   Sep 25 2023, 05:52 AM
brettrarnold   [quote name='brettrarnold' post='3103735' date='S...   Sep 25 2023, 05:53 AM
brettrarnold   What I find as the easy way to post pictures sinc...   Sep 25 2023, 05:56 AM
mepstein   [quote name='brettrarnold' post='3103735' date='...   Sep 25 2023, 06:39 AM
brettrarnold   [quote name='brettrarnold' post='3103765' date='S...   Sep 26 2023, 10:05 PM
brettrarnold   [quote name='brettrarnold' post='3103765' date='...   Sep 28 2023, 09:31 AM
brettrarnold   hello 914 crew! This post is going to be more...   Oct 31 2015, 10:48 AM
KELTY360   hello 914 crew! This post is going to be mor...   Oct 31 2015, 11:01 AM
brettrarnold   hello 914 crew! This post is going to be mo...   Oct 31 2015, 11:20 AM
Andyrew   Congrats!!! Enjoy your Honeymoon!   Oct 31 2015, 04:38 PM
PanelBilly   Get back to your honeymoon job. The rust can wait.   Oct 31 2015, 06:25 PM
injunmort   congrats enjoy   Oct 31 2015, 06:49 PM
rightpedal   Saw the update about sawzal blades on the contest ...   Jan 4 2016, 06:21 AM
brettrarnold   Saw the update about sawzal blades on the contest...   Mar 3 2016, 09:29 AM
3d914   Brett, congrats on the marriage. Hope shes as much...   Jan 28 2016, 06:59 PM
brettrarnold   Brett, congrats on the marriage. Hope shes as muc...   Mar 3 2016, 09:32 AM
rick 918-S   Tick Tock....   Jan 31 2016, 10:12 PM
brettrarnold   Alright alright, so if you have read the front des...   Mar 3 2016, 09:25 AM
DirtyCossack   #1 is the Inner Wheelhouse Restoration Design part...   Mar 3 2016, 07:44 PM
brettrarnold   Thank you Dirty Cossack for the help. Parts are o...   Mar 7 2016, 10:45 PM
914forme   Nope shop space is more important than the car. A...   Mar 8 2016, 06:01 AM
Darren C   $2K….This is just the beginning Brett, :-)...   Mar 8 2016, 06:15 AM
brettrarnold   Tonight RNellums swung by and helped me identify s...   Mar 8 2016, 10:33 PM
brettrarnold   Just a quick Garagin' update with mainly photo...   Mar 14 2016, 10:39 PM
rgalla9146   Just a quick Garagin' update with mainly phot...   Mar 16 2016, 01:01 PM
brettrarnold   I installed the bracket that will host the jack to...   Oct 25 2016, 09:45 PM
mbseto   Having kids changes your perspective on life more ...   Oct 26 2016, 07:27 AM
brettrarnold   Welding is Completed!!!! :Qarl: ...   Jan 19 2018, 11:13 PM
raynekat   Making progress....great job.   Jan 19 2018, 11:23 PM
brettrarnold   I recently purchased an EZ30D engine and transmiss...   Jan 28 2018, 02:58 PM
hockeymutt   Yea I'm in the same boat! I need a cradle ...   Jan 28 2018, 05:05 PM
mb911   I would love make these but never was able to get ...   Jan 28 2018, 08:08 PM
rnellums   Brett, don't rebuild the motor, is cheaper and...   Jan 28 2018, 09:14 PM
brettrarnold   Sweet i will make myself available if you get a ni...   Jan 28 2018, 11:08 PM
rnellums   Stick with the hydraulic clutch. After looking bac...   Jan 28 2018, 09:18 PM
brettrarnold   Junkyard find or should i buy something newer? Wo...   Jan 28 2018, 11:11 PM
rnellums   Junkyard find or should i buy something newer? W...   Jan 29 2018, 07:13 AM
brettrarnold   upullandpay near washington and 70th. saw this o...   Jan 29 2018, 08:45 AM
76-914   Make it yourself. Doesn't matter what it looks...   Jan 28 2018, 10:02 PM
brettrarnold   I like the sound of this, i have seen a decent num...   Jan 28 2018, 11:09 PM
76-914   Shouldn't be if it's early 2000's. The...   Jan 29 2018, 09:20 AM
brettrarnold   Spent the super bowl working on the seats seat and...   Feb 4 2018, 09:47 PM
76-914   Looks great! May I make a suggestion? While yo...   Feb 5 2018, 09:35 AM
brettrarnold   Yep have the heated seat kits and put in the botto...   Feb 5 2018, 09:53 AM
mepstein   Yep have the heated seat kits and put in the bott...   Feb 5 2018, 10:52 AM
mepstein   Looks great! May I make a suggestion? While y...   Feb 5 2018, 09:38 AM
76-914   Looks great! May I make a suggestion? While ...   Feb 5 2018, 11:17 PM
brettrarnold   Ya not sure myself. I saw in the master seat upho...   Feb 5 2018, 11:20 AM
mepstein   Ya not sure myself. I saw in the master seat uph...   Feb 5 2018, 11:49 AM
GenosYourGarage   New to the forum and wanted to say hello/ask a qui...   Feb 8 2018, 01:45 PM
brettrarnold   So i started in on replacing the gaskets on the ez...   Feb 19 2018, 10:21 PM
Gint   Step 1 of 2,600: Got her up on the engine stand (...   Oct 16 2020, 10:11 PM
brettrarnold   Questions for the 914 community. 1st my wife is...   Jul 17 2019, 09:22 PM
mepstein   Remove cotter pin from castle nut (nut inside of r...   Jul 17 2019, 09:33 PM
Cairo94507   :popcorn: :beer2:   Jul 19 2019, 06:45 AM
76-914   Drive the bearings and races out with a large sock...   Jul 19 2019, 08:01 AM
brettrarnold   Got the castle nut off using the impact gun!...   Jul 22 2019, 10:58 AM
76-914   I'm surprised he sourced the chains. I couldn...   Jul 22 2019, 11:59 AM
brettrarnold   I'm surprised he sourced the chains. I couldn...   Jul 22 2019, 01:40 PM
brettrarnold   The car sat mostly covered in Indiana for 15 years...   Jul 24 2019, 04:46 PM
76-914   Replace it. One of the easier pieces to do. Re: op...   Jul 24 2019, 05:33 PM
brettrarnold   Replace it. One of the easier pieces to do. Re: o...   Jul 24 2019, 05:54 PM
brettrarnold   First things first. Ive decided to name my car Ge...   Aug 11 2019, 09:34 PM
mepstein   #37 https://nemigaparts.com/cat_spares/pet/pors.....   Aug 11 2019, 09:39 PM
brettrarnold   #37 https://nemigaparts.com/cat_spares/pet/pors....   Aug 11 2019, 09:45 PM
76-914   I didn't but I made my own cradle. I can't...   Aug 12 2019, 09:59 AM
brettrarnold   Alright alright getting back into working on the 9...   Sep 24 2023, 08:23 PM
targa72e   What I find as the easy way to post pictures since...   Sep 24 2023, 09:47 PM
brettrarnold   Okay i have a couple of questions before just atta...   Sep 28 2023, 08:25 PM
- Lo-Fi Version Time is now: 3rd April 2025 - 01:56 AM
