Now that the racing/ax season is over, How many cars are now on jackstands? |
URY914 |
Nov 9 2004, 08:58 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,294 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I'm done for a few months so the car will assume its position on jack stands.
I plan on: 1. Pulling the engine 2. Adding bars to tie the shock towers to the main hoop. 3. Cutting the firewall out. 4. Cutting the passenger side floor out. 5. Replacing the targa bar with f/g. 6. Replacing the remaining steel in the rear quaterpanels with f/g. 7. Cut off the jack recievers 8. Cut out the sheet metal between the shock towers. 9. Clean up the fit of the body panels. What's everyone use got planned? If you post what you're going to do, we'll come back in 2-3 months and check everyones progress. Paul |
blabla914 |
Nov 9 2004, 11:00 AM
I like primer Group: Members Posts: 321 Joined: 1-March 04 From: Connecticut Member No.: 1,740 Region Association: None |
Jackstands?? Not yet. We've got one more AX this coming weekend. It should be interesting. Forecast calls for temps in the upper 30's - low 40's and I've got no heat in the 914.
Where's that shivering smilely? Where is there an autocross in CT this weekend? Kelly |
Lo-Fi Version | Time is now: 25th June 2024 - 12:20 AM |
