> Internal cavity rust treatment, Would/do you use Ospho?
bbrock
post Feb 2 2018, 09:33 AM
This question is specifically for those enclosed cavities that do not get opened during a full rustoration. On my car, there aren't many (inner cavities of roof pillars, roll bar, windshield frame, trunk cross member, and inside driver's suspension console). I bought a bunch of tubing to modify a garden pump sprayer so I could spray Ospho/Jasco inside those cavities. My thinking is that it would seep into seams where there is ALWAYS rust even in parts in good condition, and convert whatever rust it contacts. This would be followed by treating with Eastwood Internal Frame Coating, and finally, 3M Cavity Wax Plus. So two questions about the Ospho treatment:
1. Would you do it? It makes sense in my head, but it is spraying acid inside structural components.
2. If you did, would you follow with a water spray to neutralize the acid? My understanding is that the product forms a protective coating that can be left indefinitely, but it needs to be neutralized before it can be painted. For internals, I wonder if I'd get better long-term protection by just spraying Ospho and leaving it alone.
Thoughts?
rjames
post Feb 2 2018, 10:28 AM
I'm made of metal
I wrestled with this question, too with regards to neutralizing the internals after spraying with ospho. In the end I decided that spraying water in areas that I couldn't get to wasn't a good idea. After giving the osphy plenty of time to dry I followed it up with ehammerite or rust-oleum hammered rust cap, (I can't remember which product).
So far so good.
bbrock   Internal cavity rust treatment   Feb 2 2018, 09:33 AM
gothspeed   Sounds like you have a decent plan in place. I use...   Feb 2 2018, 09:38 AM
rjames   I wrestled with this question, too with regards ...   Feb 2 2018, 10:28 AM
76-914   I don't think your supposed to get that stuff ...   Feb 2 2018, 10:43 AM
bbrock   I don't think your supposed to get that stuff...   Feb 2 2018, 11:18 AM
gothspeed   I don't think your supposed to get that stuf...   Feb 2 2018, 01:19 PM
Rand   Yes I'd use Ospho. No I wouldn't rinse wit...   Feb 2 2018, 11:22 AM
marksteinhilber   Yes I'd use Ospho. No I wouldn't rinse wi...   Feb 2 2018, 01:15 PM
Tdskip   I have use the Eastwood internal frame coding for ...   Feb 2 2018, 01:49 PM
burton73   The new 3M (old name Minnesota Mining) stuff look...   Feb 2 2018, 02:58 PM
bbrock   I personally do not think you should put metal pr...   Feb 2 2018, 03:22 PM
burton73   The   Feb 2 2018, 02:59 PM
aggiezig   I've almost exclusively used Master Series in ...   Feb 2 2018, 03:06 PM
Perry Kiehl   If you've welded on the longs and need to trea...   Feb 2 2018, 03:16 PM
burton73   Then paint it with whatever product of your choice...   Feb 2 2018, 06:10 PM
bbrock   I've almost exclusively used Master Series in...   Feb 2 2018, 03:48 PM
BeemerSteve   I'm currently at a point of using something in...   Feb 2 2018, 04:47 PM
Rand   It's ok if it's just me, but water after O...   Feb 5 2018, 04:10 PM
Perry Kiehl   It's OK to rinse off Ospho, it's basically...   Feb 6 2018, 07:03 AM
euro911   Milt Becker (Zeke) applied Ospho after patching th...   Feb 25 2018, 12:00 PM
Costa05   Milt Becker (Zeke) applied Ospho after patching t...   Feb 25 2018, 10:45 PM
bbrock   I'm using the Klean-Strip brand from home depo...   Feb 25 2018, 11:12 PM
Perry Kiehl   I'd use a one part rust neutralizing epoxy pai...   Feb 26 2018, 07:00 AM
bbrock   I'd use a one part rust neutralizing epoxy pa...   Feb 26 2018, 08:33 AM
- Lo-Fi Version Time is now: 19th April 2025 - 06:28 PM
